pressure plate to flywheels bolts
  • haaken675
    • Sep 2016
    • 601
    So I managed to strip a few of the pressure plate bolts with an improperly sized allen key. I found the part number on real oem, but pelican and ecs tuning want way to much money for a small bolt. Can I get these at a hardware store, or are they somehow special?
    Thanks
  • jeffnhiscars
    • Jun 2011
    • 6010
    Not sure if those are 8.8 or higher but I would think as long as they are the correct grade you should be fine.
    Alice the Time Capsule
    • Dagamus(NM)
      • 618
      Aren't these specific torque to yield bolts?
      Gun control means using both hands
      Sex, Drugs, Rock 'n roll. Pick two.
      • AndrewBird
        The Mad Scientist
        • 11898
        Not the ones holding the pressure plate to the flywheel. They are small M8 cap head machine screws.
        I wouldn't hesitate to get some from the hardware store. Like Jeff said, just get the same grade and you will be fine.
        Looking closely at the picture FCP Euro has on their website, it is an 8.8 grade.
        • haaken675
          • Sep 2016
          • 601
          :up:
          Perfect, Thanks guys!
