Won't go into first gear sometimes
  • imjusthere
    • Jul 2014
    • 119
    On occasion my transmission won't shift into first gear. It used to be super infrequent but it's happening more and more often now. When it does happen I press the clutch in several times and eventually it will engage. I've changed the transmission oil but it didn't help. What could this be and what do I do next?
    Sent from my Pixel XL using Tapatalk
  • TobyB
    • 5263
    Try bleeding the clutch slave, and if that doesn't help, see if you can see
    a fluid leak, either at the slave or master.
    It sounds like the clutch isn't disengaging fully.
    t
    • jeffnhiscars
      • Jun 2011
      • 6011
      Or they re leaking internally which you wont see. The fact that pumping the clutch seems to help , means you have a hydraulic problem.
      Alice the Time Capsule
