Flywheel question
  • Steve Corbett
    • Jul 2012
    • 449
    Flywheel question
    I have a low mile flywheel from my1984 528E, It is pictured on top. It is lighter and assuming it is a single mass. The bottom is from a unknown 325I, it is heavier but still seems to be single mass? Either could be used in my 89 325I W/5 Speed Swap, correct? I would prefer the lighter.
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
  • TobyB
    • 5199
    I'd use the one with the better ring gear ;)
    However, I'd also measure- there are different depth
    bellhousings, and I'd crassly assume that there might
    be different depth flywheels, as well. I'm not 100% clear
    on the sensor pegs on an eta flywheel, but make sure they
    don't hit the bellhousing...
    Also, check the crank bolt length- there should be a hardened spacer
    between the bolt heads and the flywheel. And there may be a difference in flywheel thickness.
    Things that have caught me out,
    t
    • AndrewBird
      The Mad Scientist
      • 11898
      Whichever you end up using, get it re-surfaced. Both those look rough.
      • jeffnhiscars
        • Jun 2011
        • 6010
        It may be the optics but the bolt patterns look different ?
        Alice the Time Capsule
        • Steve Corbett
          • Jul 2012
          • 449
          Bolt pattern is the same, I checked using the hardened spacer.
          Steve Corbett
          1983 528E Scrapped
          1983 528E Sold
          1984 745I
          1984 325E - Sold
          1989 325I Zinno
          1988 635CSI
