Alternative center support that is sturdier?
  • Flash
    • 688
    The E32 one will fit the E30 chassis but it is offset (mounting) and wont work correctly, but the e36 center support is much more robust looking at a pic of it, and is in the center of the mounting points. Does anyone know from hearsay or experience a better one than the thin, flimsy ones that you get from say autohausaz? The MTC brand for example.
  • Wanganstyle
    • 2828
    bmw dealer supplied center support for driveshafts seem to live the longest; cost is high though in compared to many inexpensive aftermarket.
    • Northern
      I like cupcakes & sh!tboxes
      • 5283
      Plenty of people use the stock E30 one without issues at well above stock power. If yours is continuously failing, it is probably a symptom of another issue, and not the cause.
      Also, I think the switch to the offset CSB was 09/1987, or so says RealOEM, so if your car is later than that, you should be looking to keep the offset the same.
      Originally posted by priapism
      Originally posted by shameson
      • Bearmw
        • 1323
        I have done the hack approach by using
        Weatherstrip adhesive to attach some rubber vacuum hose to the cavity to reinforce it . Hasn't failed yet....
