Anyone ever rebuild a clutch master?
  • 2mAn
    SeƱior Mod
    • 21094
    Im looking at some of the new masters out there and Im thinking that rebuilding the OEM one is a better move than buying some second rate one
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • e30davie
    • Apr 2016
    • 1788
    If the bore is not damaged you can just disassemble and replace all the seals. The bore needs to be absolutely perfect though, even the tiniest of rust/scratch marks in my opinion it goes in the bin.
    I bought a brand new german brand clutch master for $120 AUD including the little plastic doovey and new pipe from the resevoir to the master. I think it would be hard to rebuild it for cheaper when you take into account what your time is worth. Unsure how much a seal cut costs (if you can even buy one).
    • AndrewBird
      The Mad Scientist
      • 11898
      Rebuild is easy, should take less than an hour. If the bore isn't perfect, you can hone it to clean it up.
      • Wanganstyle
        • 2828
        buy new FTE master; problem solved.
