Clutch shudder when warm/in traffic
  • berndt
    • Mar 2016
    • 104
    I think I’m on the original clutch, so pretty sure the diagnosis is likely worn out clutch. Car has 170k miles. Noticed slight judder for a while, but it was never serious. Today traffic was terrible and it was a LONG line of stop and go. Judder got considerably worse and made some bad sounds. I turned down some side streets to let thing cool down and got home OK. Is this a symptom of a failing clutch?
    Of course it happened the same day I had my e39 towed after it died. Ugh!
  • TobyB
    • 5256
    Could be-
    are you leaking oil out the rear main?
    I had a beater pickup that did this, and
    it was oil...
    The fix is the same either way, tho.
    t
    • berndt
      • Mar 2016
      • 104
      I am leaking, yes. Quite a bit. Either way, transmission comes off, so will replace both :/.
      • Northern
        I like cupcakes & sh!tboxes
        • 5234
        My M52 does this when I'm in stop and go traffic when it's hot out. New rear main 2 years ago with no signs of leaks, figured it was the FX Racing flywheel/ 6-puck.
        I adapted my driving habits in heavy traffic to use the clutch less.
        Originally posted by priapism
        Originally posted by shameson
