I hate previous owners!
  • Rugbyfan
    • Jun 2011
    • 286
    So I went to replace my drivers side rear wheel bearing. The previous owner WELDED the axle nut to the base plate. Any ideas? The welds prevent the socket from fully seating.
    "Broke into the wrong God damn rec room, didn't ya you bastard!"
  • uturn
    • Dec 2010
    • 1005
    Hammer, chisel and file.
    • Rugbyfan
      • Jun 2011
      • 286
      On closer inspection they welded the nut all around the inside of the hub. Who does that?
      • TobyB
        • 5280
        Previous owners!
        Angle grinder time.
        Then new hub...
        t
        • noid
          • 1537
          Lets see some pics.
          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
          Your resource to tools and tips: www.rtstools.com
          • Rugbyfan
            • Jun 2011
            • 286
            I’m heating, drilling, chiseling. I have no idea how this nut is still holding on. The hub is trashed. I’ll get some pics
            • AndrewBird
              The Mad Scientist
              • 11898
              Sure it's not just the lock plate?
              • Rugbyfan
                • Jun 2011
                • 286
                Yup. Definitely welded. I got it off. FYI a 19mm metal hole saw fits perfectly over the axle without damaging the threads. I went through 3. I nicked the threads slightly with my drilling. I think I can save the axle but I’m still searching for a hub at a price that isn’t $300. I took a ton of pics and will figure out how to post them when work slows down
                • Rugbyfan
                  • Jun 2011
                  • 286
                  Got the hub off and bearing out and new bearing in. If the nut is seized the hole saw method works great. If the bearing is seized and you don’t have tools then make your own with 5/8x10” bolt, 46mm 3/4in drive socket, washers, pvc etc. HEAT the shit out of the bearing/trailing arm with propane.
                  • Rugbyfan
                    • Jun 2011
                    • 286
                    Still hating previous owners. So I have the new hub in hand and it’s different from the old hub. My car is an 87 325is with an April build month. The replacement hub is the new variety. The old hub does NOT have a beveled edge and has raised bumps on the back. It has the numbers 1129106. What car did this hub originate from? The passenger side is NOT welded and it’s approproately assembled. I’m thinking the previous owner butcher the driver side rear hub and replaced it with the incorrect one and that’s why he welded it.
