Bad CSB, Driveshaft balance?
  • Nick_e30
    • Mar 2016
    • 173
    My 3rd csb is bad why does this keep happening. A new center support bearing only gives a temporary fix. Does my driveshaft need to be balanced?
    Sent from my SM-G950U using Tapatalk
  • e30davie
    • Apr 2016
    • 1788
    How are your:
    -engine mounts
    -gbox mounts
    -uni joints on drive shaft
    • Nick_e30
      • Mar 2016
      • 173
      Mounts are new and I was told the joints and giubo were good when the first csb was replaced about 2 months ago
      Originally posted by e30davie
      How are your:
      -engine mounts
      -gbox mounts
      • tomstin
        • Mar 2015
        • 570
        Was the CSB pre-loaded properly? That will kill a CSB pretty quick.
        2004 525i Manual - 1985 325E Coupe Manual
        • mmire30
          • Dec 2009
          • 50
          How do you pre-load the CSB?
          • ForcedFirebird
            • Feb 2007
            • 8300
            If the giubo is installed wrong, it causes bad vibration and take out the CSB. There are arrows on it that have to point at the flanges. If you notice, the giubo has thick and thinner portions between the bolt holes. The thick part should be compressed in forward gears.
            Another thing I have seen cause it is half shafts with excessive play. Jack one rear side up at a time and rotate the wheel with it in gear. There should be very little movement.
            john@m20guru.com
            Links:
