Rear Diff
  • wholepailofwater
    • Apr 2018
    • 63
    Rear Diff
    Need some help, the rear diff fill bolt torx "thread" is completely stripped out its know just a circle. Any ideas on how to get the bolt out so I can get a new one on?
    Thanks
    JP
    1984 533i
    1984 733i
    1985 325e
    1998 M3
    1998 318ti
    2008 335i
  • sgtskid
    • 763
    Two Options:
    1. weld a bolt to it and then use the head of the bolt to back out the torx
    2. drill a hole in it and then use one of these guys
    Ez-Out
    Current: '91 DS M3, '03 TS M3 (6MT)
    '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
    Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
    1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
    IG: RDE_Fabrications
    Check us out
    Or YouTube --> HERE;
    • KIRIEIW
      • Dec 2012
      • 3385
      I would try and avoid drilling into the bolt just cause shavings could enter the diff, also they use a allen for the fill plug not a torx. Kind of a tough one to remove, the spare tire well is pretty close too for access.
      1992 e34 Touring- S50 Swap
      1992 325i-S50 Swap (SOLD)
      1991
      • wholepailofwater
        • Apr 2018
        • 63
        Thanks, ya the clearance between the spare tire and the diff is kinda tight. I don't think you could get an ez out in there. And yes drilling would be sketch cause of all the shavings. Thinking about taking off the whole rear cover. Is this possible with the diff still in the car? It looks like its do able.... Never done it on an e30 though
        Thanks
        Jp
        1984 533i
        1984 733i
        1985 325e
        1998 M3
        1998 318ti
        2008 335i
        • roguetoaster
          Biggus Tippus
          • 7830
          Yes, you should be able to remove the cover with it in the car.
          • wworm
            • Dec 2016
            • 1719
            iirc the whole rear cover should come off no problem as long as the rest of the diff is bolted to the subframe. Just gonna really release the gear oil stink right in your face lol.
            1984 Delphin 318i 2 door
            • ForcedFirebird
              • Feb 2007
              • 8300
              There's a lip on the plug, just snap some vice-grips on it and they come out easily.
              john@m20guru.com
              Links:
              • wholepailofwater
                • Apr 2018
                • 63
                Ordered this set, found it cheaper but the link didn't work.
                Hopefully this will get it out. Tried the vice grips but no dice. I think this things on tight, that's why whomever tighten the living crap out of it stripped at the same time.
                Jp
                1984 533i
                1984 733i
                1985 325e
                1998 M3
                1998 318ti
                2008 335i
                • wholepailofwater
                  • Apr 2018
                  • 63
                  Extractor set got here on Friday, finally had some time on Sunday to work on the fill plug. Now I know why it was stripped out. Whom ever messed with it last, put it on tighter than a crabs ass. They must of been to lazy to replace the .56c washer cause it was deformed and smushed to hell. Anyways got it off and got the updated plugs. Anybody now the size for the updated plugs? bigger than anything I have.
                  JP
                  1984 533i
                  1984 733i
                  1985 325e
                  1998 M3
                  1998 318ti
                  2008 335i
                  • TobyB
                    • 5243
                    14mm, I do believe.
                    It was kind of hard to find- had to order it...
                    t
                    • wholepailofwater
                      • Apr 2018
                      • 63
                      Thanks, I'm going to bring one with me and go see the Snap On guy and see what he's got.
                      JP
                      1984 533i
                      1984 733i
                      1985 325e
                      1998 M3
                      1998 318ti
                      2008 335i
