260 Fluid Type Sticker Location?
  • HerbE30
    • Nov 2015
    • 538
    I am not able to locate the sticker for the fluid type... As title states. I saw the VIN number sticker and assumed it would be beside it. I am near positive its a 17mm allen to remove.
    Its a '90 Getrag model, if anyone knows the fluid off the top of their head.
    Also having a little bit of resistance from 1st to 2nd, but mostly in the higher RPM, so assuming a syncro issue. I guess there would be a better fluid to combat this?
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • jeffnhiscars
    • Jun 2011
    • 6011
    My understanding is that the sticker told you what was installed at the factory but that they are all interchangeable. Personally I've always used MTL regardless of the sticker
    Alice the Time Capsule
    • LowR3V'in
      • 4209
      ^ this isn't fact but i have a atf type tranny but chose the mtl.
      i was researching and even the e46 guys that use the atf stuff switch over to the mtl and notice nicer shifts.
      the redline fluid would be d4 (atf) or mtl.
      just google d4 vs mtl it's all bmw posts.
      http://www.1addicts.com/forums/showthread.php?t=1016051
      • kronus
        • Apr 2008
        • 13032
        If the drain/fill plugs are innies, it took gear oil at the factory. If they are outies, it took ATF.
        cars beep boop
        • TobyB
          • 5298
          What if there's one of each?
          t
          • kronus
            • Apr 2008
            • 13032
            then you fill it with thai peanut sauce
            cars beep boop
