89’ 325i Motor compatible w/ 87’ 325e?
  • Jacksuave
    • Sep 2018
    • 8
    Hello everyone! I just got my first E30 so I’m new to the Euro world. My question is (aside from the ECU and Wiring Harness) will an 89’ 325i motor essentially be a direct fit into my 87 325e and mount to the stock 260/5 Getrag? Eventually I’m going to tear my old Eta motor and build a “stroker” but the 325i motor was running well and taken off a donor car. It’ll also give me the excuse to upgrade to the 1.3 motronic. I’ve tried doing some extensive research. Sorry if there’s a thread I missed about this. Thank you for your time!
  • TobyB
    • 5271
    Pretty much.
    Pay attention to your eta total flywheel + clutch thickness...
    Depending on the month of your chassis, you might have to move a pin or 3
    in c101- the only danger,and it's low with an 89 donor, is pin 20.
    Make sure it's not connecting fat red to fat green. That gets stinky.
    was invaluable when I put a 91 engine into an 87.
    hth, and welcome.
    t
    • Jacksuave
      • Sep 2018
      • 8
      Awesome! Thank you very much
