Loud Transmission Noise
  • zippityDu
    • Feb 2019
    • 126
    As I pulled into my driveway yesterday and put the car in park, the "Brake Lining" light came on and the car started making a very loud screech. I turned it off and back on and it was still there. Whenever I put the car in reverse or drive, the noise would go away. Can anyone help me diagnose what is going on?
  • jeffnhiscars
    • Jun 2011
    • 6011
    The brake lining light is a grounding sensor that signals a thin pad regardless of whether the vehicle is moving or the engine is running so it won't cause a noise. The light is also famous for being on for no good reason.
    As for a noise you only hear in neutral ��waffles♂️
    Alice the Time Capsule
    • TobyB
      • 5271
      You'll need to figure out where the noise is coming from...
      t
