Meyle HD Flex Joint/ Giubo?
  • Tmavého na Světlo
    • May 2018
    • 8
    Has anyone had experience with the Meyle HD flex joint/ giubo? The price for the kit with the replacement hardware is a good deal but want to make sure it's a good replacement before buying.
  • TobyB
    • 5298
    Wouldn't trust it based on other recent Meyle experiences, but I haven't tried that
    specific part from them.
    t
    • ForcedFirebird
      • Feb 2007
      • 8300
      Meyle is one step above URO (URO = pure Chinese junk).
      Spend the extra ~$20 and get a Bilstein/Febi, or you will be doing the job again in a few thousand miles to save that $20. Just my opinion...
      Also, pay attention to the arrows on the giubo, they need to point at the flanges on the trans/output, or any brand will shred quickly and look like a rubber infused floor mop in short order.
      john@m20guru.com
      Links:
      • Tmavého na Světlo
        • May 2018
        • 8
        t
        Thank you for your input, I ended up ordering it the morning after I posted. I figured if it ended up failing early, I'd just get it replaced from FCP Euro, and it's not that hard of a job. It just arrived and it's in a nice box and it says it's made in Germany. I hope it is durable.
        • Tmavého na Světlo
          • May 2018
          • 8
          Thank you, I appreciate the tip and will make sure it is correct.
          • TobyB
            • 5298
            That's good news, and somewhat unexpected- I'd give it the benefit of the doubt, then!
            t
            • ForcedFirebird
              • Feb 2007
              • 8300
              Part made in Germany, or the package?
              john@m20guru.com
              Links:
