Is this an LSD?
  • ryan.of.peachey
    • Apr 2019
    • 77
    Is this an LSD?
    Can anyone tell from this photo if my diff is LSD or not? I'm thinking it's not, but need to know what kind of fluid to fill it with. Thanks.
    Sent from my SM-G960U using Tapatalk
    1988 Alpinweiss 325i Convertible
  • LJ851
    • 7919
    yes, lsd
    Lorin
    The M30 is God's engine.
    • ryan.of.peachey
      • Apr 2019
      • 77
      Thanks. I couldn't tell because the tag was too rusted.
      • Andre3127
        • Dec 2017
        • 291
        Google it. Seriously.
        If both output shafts spin together it's an LSD.
        Budget E30 Parts - Used and Reconditioned parts for your BMW
        • ryan.of.peachey
          • Apr 2019
          • 77
          Thank you.
          • roguetoaster
            Biggus Tippus
            • 7830
            Unless it's a mechanical locker like a torsen.
            • agent
              Vice Grand Pubaa
              • 7960
              General Discussion is not a catch-all; please do not ask technical questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
              Originally posted by kronus
              • ForcedFirebird
                • Feb 2007
                • 8300
                I prefer Redline 75w90 or comparable GL-5 fluid in clutch typs LSD's (such as a stock e30 would have).
                ...or helical, but highly unlikely in an e30 diff....Torsen came in some z3 diffs, though.
                john@m20guru.com
                Links:
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  You can sometimes provide enough load on one output flange to cause a torsen to show function, haven't had a chance to try a helical setup the same way.
                  As an aside, torsens aren't bad in the snow and icy stuff the way I thought they might be, as long as you have even a little grip somewhere you'll go, and when you don't you can brake torque it.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Both Torsen and helical will act like an open when one wheel is completely unloaded. This is why they both rotate the opposing wheel opposite when sitting on a bench.
                    Quaife is a 100% helical (I used one in the ls1 swapped Mercedes), but they both actually act similar when a wheel if lifted, but deceleration is argumental.
                    Torsen:
                    Helical:
                    EDIT: Now a viscous acts in a very different way - kinda like a torque converter does in a slushbox transmissions:
                    john@m20guru.com
                    Links:
                    • The Dark Side of Will
                      • Jun 2010
                      • 2796
                      A clutch pack (Salisbury), Torsen or Quaife can all load up and prevent wheelspin, up to the limit of their capability.
                      A viscous unit can only react to wheel spin.
                      I thought Quaifes had a small clutch pack or preload spring in the center that gave them something to push against so they can move the car even with one wheel off the ground.
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        I thought Quaife was another name for Torsen
                        Alice the Time Capsule
                        • Wanganstyle
                          • 2828
                          Torsen type 2 units have a couple clutch packs so you can move the car in san Francisco parking situations (one wheel airborne). Does nothing when on the track flat out with one wheel airborne
                          S2000 Under The Hood - Factory Torsen differential internal guts inspection, reassembly - Post is to share the detailed internals of a Torsen Type 2 and how it is assembled; timed -these units are rather set from the factory engineers and the only tuning would be to add/reduce drag - fluid changes would be more...
