OBX Helical LSD
  • asubimmer
    • 6482
    #31
    Originally posted by CarsSuck
    Why not just upgrade to a large case? Won't you be needing it with the turbo anyway?
    yup....I was gonna get a 3.73lsd for $35 and it didn't work out lol
    • matt
      • 3731
      #32
      Originally posted by Mossman
      anybody have a reason why 325e's and 328i's supposedly have the same diff, yet it's different than e30 and e36 325i's.
      I think I'm gonna guinee pig this but I want to make sure this company knows at least something about BMW fitment before I spend $400.
      Huh? All 6 cylinder e30s and e36s (except euro M3) have the same diff *size* (different case, same LSD will fit, except e36 M3)
      • Mr Deagle
        • 1121
        #33
        ot, but can you put limited slip clutches in a non lsd case? like is there the provision for it?
        • matt
          • 3731
          #34
          You have to swap the whole differential. The inner part. The cases are the same.
          • 325Projectz
            • Jan 2005
            • 1956
            #35
            Huh, I was looking at these tonight on the bay... Then I run across this thread.
            Well if no one buys one anytime soon, I'd be up for the job, but that won't be for another 2 months or so.
            91 m3
            • golde30
              • 11464
              #36
              OBX Is local to me. i have been to their shop a few times as my buddy buys wholesale from them. maybe i will hitch a ride with him next time and pick their brains about these units.
              IG: @Baye30
              • 325Projectz
                • Jan 2005
                • 1956
                #37
                Hitch a ride to their warehouse and put one in your pocket. Report back.
                91 m3
                • Jean
                  • 18228
                  #38
                  Do it. I asked a buddy of mine who is heavily into drag racing and said some guys do run them in fwd imports w/o trouble but couldn't get any more info... lame.
                  • ummagawd
                    • Jul 2006
                    • 144
                    #39
                    i'm ready and willing to experiment with this but I have a few hurdles,
                    1 - i have a 92 318ic and thus have the 4.27 open diff... i'm not sure they make one that works...
                    2 - if they do make something (or i somehow get my hands on a medium case 4.1 diff)... i would need someone with the proper tools to install it into the diff (i can install the actual diff itself into the car)
                    and then i can report back my findings... and trust me... i'll try and break it
                    • xLibelle
                      • Aug 2004
                      • 2673
                      #40
                      the regular lsd works just fine
                      though i would love to learn how to service them
                      • matt
                        • 3731
                        #41
                        WR has one out of the case... haven't gotten around to messing with it yet. Probably this summer.
                        • DJB
                          • Oct 2005
                          • 195
                          #42
                          From what I've read, the key tool to service diffs is a bearing drag measurement tool. You have to tighten the pinion nut until the torque needed to spin the input shaft at 30rpm matches the specified value. That's not a tool that you'll find at your local store.
                          About the only way I can think of quickly making one is combining a battery screwdriver/drill set to 30rpm with a beam-type torque wrench.
                          You'll also need a complete set of shims for both the pinion position and the output flanges. The BMW list price on a "set" isn't cheap, especially if you'll need several sets for each diff.
                          • moatilliatta
                            • 6150
                            #43
                            if you get 80 people to donate 5 dollars each to me... ill try it
                            @Zakspeed_US
                            • matt
                              • 3731
                              #44
                              All you need to measure pinion drag is a fine 0-20in/lbs torque wrench.
                              We always measure rear ends and order the proper shims here at work. I don't think a whole set is needed in stock to setup a diff.
                              I believe he's talking about servicing an LSD unit, not the entire diff itself.
                              • sumyungguy
                                • Feb 2007
                                • 1313
                                #45
                                Honda guys have been using them for a while, they haven't had any problems.
                                Theres even a OBX LSD FAQ thread on Honda-tech.. HERE
                                read through it and check out the links...
