OBX Helical LSD
    Originally posted by CarsSuck View Post
    Why not just upgrade to a large case? Won't you be needing it with the turbo anyway?
    yup....I was gonna get a 3.73lsd for $35 and it didn't work out lol
      Originally posted by Mossman View Post
      anybody have a reason why 325e's and 328i's supposedly have the same diff, yet it's different than e30 and e36 325i's.
      I think I'm gonna guinee pig this but I want to make sure this company knows at least something about BMW fitment before I spend $400.
      Huh? All 6 cylinder e30s and e36s (except euro M3) have the same diff *size* (different case, same LSD will fit, except e36 M3)
        ot, but can you put limited slip clutches in a non lsd case? like is there the provision for it?
          You have to swap the whole differential. The inner part. The cases are the same.
            Huh, I was looking at these tonight on the bay... Then I run across this thread.
            Well if no one buys one anytime soon, I'd be up for the job, but that won't be for another 2 months or so.
            91 m3
              OBX Is local to me. i have been to their shop a few times as my buddy buys wholesale from them. maybe i will hitch a ride with him next time and pick their brains about these units.
              IG: @Baye30
                Hitch a ride to their warehouse and put one in your pocket. Report back.
                91 m3
                  Do it. I asked a buddy of mine who is heavily into drag racing and said some guys do run them in fwd imports w/o trouble but couldn't get any more info... lame.
                    i'm ready and willing to experiment with this but I have a few hurdles,
                    1 - i have a 92 318ic and thus have the 4.27 open diff... i'm not sure they make one that works...
                    2 - if they do make something (or i somehow get my hands on a medium case 4.1 diff)... i would need someone with the proper tools to install it into the diff (i can install the actual diff itself into the car)
                    and then i can report back my findings... and trust me... i'll try and break it
                      the regular lsd works just fine
                      though i would love to learn how to service them
                        WR has one out of the case... haven't gotten around to messing with it yet. Probably this summer.
                          From what I've read, the key tool to service diffs is a bearing drag measurement tool. You have to tighten the pinion nut until the torque needed to spin the input shaft at 30rpm matches the specified value. That's not a tool that you'll find at your local store.
                          About the only way I can think of quickly making one is combining a battery screwdriver/drill set to 30rpm with a beam-type torque wrench.
                          You'll also need a complete set of shims for both the pinion position and the output flanges. The BMW list price on a "set" isn't cheap, especially if you'll need several sets for each diff.
                            if you get 80 people to donate 5 dollars each to me... ill try it
                            @Zakspeed_US
                              All you need to measure pinion drag is a fine 0-20in/lbs torque wrench.
                              We always measure rear ends and order the proper shims here at work. I don't think a whole set is needed in stock to setup a diff.
                              I believe he's talking about servicing an LSD unit, not the entire diff itself.
                                Honda guys have been using them for a while, they haven't had any problems.
                                Theres even a OBX LSD FAQ thread on Honda-tech.. HERE
                                read through it and check out the links...
