I am trying to replace the output shaft seal :
Got the 30mm nut and the lock washer removed. Trying to remove the flange from the shaft with a 3-jaw puller. It takes a lot of force but the flange doesn't budge.
Is there any trick/tip to removing it ? I don't want to break the flange !
Is there a internal circlip or something holding it back ?
thanks,
Bala
thanks,
Bala
