2nd gear vibration
  • accident
    • 7303
    Originally posted by kencopperwheat
    I'm having this same issue now. Is it easy to tell if the rubber mount of the csb has failed?
    What should I be looking for? I'll probably just end up putting in a whole new driveshaft assembly.
    The rubber around the bearing itself will usually be shredded or at least torn if this is the case. I cant remember if the CSB is under one of the underbody pieces or not, but you may be able to see it through a space in between them if it is.
    Moral of this story?
    • kencopperwheat
      King of Kegstands
      • 14396
      If, as stated above, the shearing of the rubber CSB mount is usually caused by the driveshaft u-joints binding, is there anything on the u-joints that I would be able to see?
      Originally posted by Gruelius
      • accident
        • 7303
        My CSB rubber was completely trashed and my u-joints are just fine.
        • kencopperwheat
          King of Kegstands
          • 14396
          So you just replaced the CSB and all of the vibration is gone?
          • accident
            • 7303
            yep. I'd replace the guibo while you're under there, mine was starting to crack when i did the CSB and you might as well do both while you have the driveshaft off.
            • kencopperwheat
              King of Kegstands
              • 14396
              Cool, thanks. I'll try just replacing the CSB first. My guibo only has about 600 miles on it.
              • accident
                • 7303
                And with all that angry vibration it's probably begun to crack.
                • Burning2nd
                  • 98
                  i think i have the same problem.
                  shafts gonna have to come on out..
                  i have the csb
                  04 e83 X3
                  01 e39 540M
                  97 e36 328is
                  Specializing In BMW, Audi, Mercedes Benz, Porsche ,Volkswagen
                  • cowden_12
                    • 354
                    My CSB resently took a shit on me. Car was smooth until one day she went. I replaced CSB and guibo while under there. At first car seemed fine. Now i have vibration again through first and second but levels out 3 through 5. ?
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Ditto... I just replaced my CSB and the vibration is still there.
                      How do I check for binding in the U-Joints? Mine didn't seem all that smooth when I moved them around out of the car...
                        As to how to tell if the u-joints are binding...
                        One diagnostic is a failure of the rubber mount of the CSB. The other is to compare what the u-joints feel like to what u-joints in a new drive shaft feel like. If you don't happen to have access to a new drive shaft or have never felt the u-joints in a new drive shaft, go with the first option.
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          My CSB was pretty worn out. I replaced it with a used one that seemed pretty good and I'm still having the same issues.
                          I have some known good used drive shafts that I can compare the joints too though.
                          • cowden_12
                            • 354
                            Any luck with the driveshaft problems?
                            • 87e30
                              • Jul 2008
                              • 5676
                              My CSB is torn as well. And I get a really bad vibration in the same range as everyone else. My guibo looks good though, it's not cracked at all.
                              Where could I find a GOOD replacement driveshaft and how much would I be looking to spend.
                              Also, is the driveshaft u-joint supposed to be easier to flexone way than the other. It flexes one way pretty far and easily, and the other direction not so much and it's harder to move.
                              I just hate everyone.
                              No need for discretion.
                              • hoveringuy
                                • Dec 2005
                                • 2722
                                FWIW, I just pulled my driveshaft because the center bearing was torn a few months ago and replacing it didn't help. I was getting a vibration around 2,000 rpm under acceleration.
                                I ordered a replacement from Driveline Service of Portland.
                                The old driveshaft had a really tight U-joint in the rear. No play at all, but very hard to move back and forth. I talked to the Driveline Service guys and they said that's the "classic" symptom of a bad driveshaft that will cause that vibration. The U Joint doesn't move, so the WHOLE DRIVESHAFT MOVES!
