4.10 LSD swap
  • naplesE30
    • Nov 2007
    • 1841
    4.10 LSD swap
    Will a 4.10lsd from a 89 325i auto swap into a 91 318is 5spd? If so is there any way to tell what shape a diff is in if it is already pulled?
    Thanx
  • kenika65
    • Aug 2007
    • 1336
    yep open it up and look inside then use rtv sealent to seal it up.
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
    • naplesE30
      • Nov 2007
      • 1841
      Ok so I swapped in the 3.73LSD and it whent in fairly easily. Much quieter then my worn out 4.10. However, now I am hearing a very slight whine at like 50+ mph but only when coasting or decelerating. Also it clunks when changing or engaging gears. Does that sound like a CV joint going?
      • mattdk318i
        • Jun 2006
        • 3953
        that means the 3.73 was on its way out too. But just hasnt started making too much noise. I assume you changed the fluid in it?
        I just bought a 89 325 and it clunks like something terrible. Reminds me of driving an old chevy with bad UV joints
        • naplesE30
          • Nov 2007
          • 1841
          I checked, changed the fluid and it was clean. The whine doesnt sound like its comming from the diff. I am seriously thinking about installing new wheel bearings as I have been thinking they may be going. I checked the u joints and there is no play. It just seems like there is slack somewhere in the rear end and that is the culprit of the clunking and whine. On a different note I love the gearing of the 3.73! I lose a little off the line but on the highway it soooo makes up for it.
          • allwheeldrive
            • Jan 2008
            • 272
            u-joints can become noisy, clunky and can create alot of vibrations when going bad.
