I have an automatic transmission in an e30 that I just purchased. It is a 6/87 build and has an M20B25 i motor. It seems to shift weird. It down shifts as I slow down almost like an SMG tranny, and I have to get it really high in the revs to get it to up shift (over 5k rpm). After it is warmed up it will not shift higher than 3rd or will not shift into 4th gear OD.
Is there a separate ECU for the trans? or is there a specific ECU for an automatic equipped E30. When I purchased the car it had a lot of spare parts. I notice that there was an extra 0 261 200 153 ECU among the extra parts. The car is running on an 0 261 200 173 ECU. I noticed that there is also an 0 261 200 525 listed for the e30, typically for Automatics. Should I be running the 153, 173 or 525 ECU or is there no difference?
Anything else I should check for? I checked the fluid once already and it seemed to be fine, doesn't mean that it is though.
Thanks in advance for your help.
Aaron
Aaron
