here is the scope of everything
-shifts fine when the car is off
-engine on, can't get into ANY gear AT ALL*** (see lower)
-once you get it rolling, it will shift semi-smoothly, no grinds no noise or anything else!
-When the engine is on, I press the clutch pdl. and try get into first, basically rocking the car forward until it catches and starts going slowwwly. (that's how i got it to roll, it would shift to 5th no problem once up to speed at 70, basically driving fine...)
-When I filled the tranny with mt90, there were no shavings or anything like that!
-The tranny is a getrag 260 from an m20 E34, the output shaft was different, but i mated it with E30 "i" driveshaft no problem (swapped flange and shortened the rod (widened the driveshaft hole). No vibrations at all at any speed.
All the clutch components are new. I've tried using a slave from e34 (m20 car), no change. the floor inside seems to be dry, but I haven't looked at master yet... everything bleeds fine!
The flywheel is single mass and the clutch is single mass also.
I've had a getrag 260 from E30 in it before this one, but that was grinding 3rd and it was driving fine, so I swapped it to this....:(
I would apreciate any help from you guys! I can't pull the tranny untill the weekend, so we can just discuss everything here, any possibilities.
update, I've tried just to see if it will engage.
once the car is on, it doesn't wanna get into first or second at all. It takes a HUGE force to get it into third, less fourth and little force in 5th. Can the tranny be bad? even though under driving conditions it shifts fine? WTF is wrong... I checked master, everything is bone dry...
