Replaced clutch, flywheel, TOB, etc. Actually manual swapped the car.
Clutch successfully bled last night. It is making a bit of noise when depressed, but only partially depressed. Like right at the engagement point, once the pedal is all the way down it's quiet.
If it's a noisy t/o bearing I would think it would make noise the entire time the pedal is pushed?
Will the disk make noise as pressure is coming on and off it?
