Driveline angle
  • RainRider
    • Aug 2014
    • 362
    Driveline angle
    Just put in a clutch in my e30 swap. Zf 320 trans. Put it back together the way it was before I dropped the tranny. I didn't notice any driveline angles during disassembly but I didn't look for it either.
    Does this look right? The car had no driveline issues before.
  • roguetoaster
    Biggus Tippus
    • 7830
    Wow, unless it was canted because of the swap it's not optimal, but probably won't break itself immediately at that angle.
    Check engine/trans mounts, diff/subframe bushings. Can't tell with the pic, but looks like the center bearing isn't mouted correctly or is moved for some reason.
    • AndrewBird
      The Mad Scientist
      • 11898
      The rear section looks ok, judging from the distance from the fuel tank on each side. The engine looks shifted to the passenger side for some reason. Maybe the motor mounts are turned 180°?
      • RainRider
        • Aug 2014
        • 362
        I'll pull the driveline again, lift the engine and start over. Post back what I find. Thanks for the replys.
        • reelizmpro
          • 9537
          You stated you didn't notice it before. Did you use a later E36 shaft with an E30 CSB installed backwards? That's how mine was before I swapped it out for a rebuilt big flange ETA driveshaft. It bolted right in and is straight as an arrow now.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • iansane
            • 1342
            The CSB looks backwards...
            84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
            • RainRider
              • Aug 2014
              • 362
              It was the CSB. Turned it around this morning and it's straight now. Noticed nothing with it at an angle for the last 5 years.
              • The Dark Side of Will
                • Jun 2010
                • 2796
                Good both to find a solution and have a data point.
