Reality check on 5spd swap/linkage
  • ainadude
    • Apr 2008
    • 221
    Bought my 91 coupe from a shop in Reseda, CA. Car was originally an auto; shop owner did a 5spd swap. Linkage is horribly sloppy -- owner claims that's because mounting points are different between the two transmission setups. I smell bullshit but thought I'd check with the experts. Car runs great otherwise. Linkage is fine up and back. Crazy sloppy laterally, tho -- shifter slightly contacts trim surround piece when I go into reverse.
    Really like the car but shift linkage is the last major functional issue keeping me truly enjoying having an e30 again. My previous e30 came with a 5spd from the factory and linkage was fine.
    ainadude
    Indian Wells, CA
    1991 325i 2dr. 5sp, delphin, w/freshly re-skinned IS sport seats/15" Ronal cross-spokes
    1976 Triumph Spitfire w/1.8-liter Miata engine/transmission, koa dash with TR6 oil/volt gauges, lowered suspension, 14" Minilite replicas and more
    2004 Kawasaki ZZR600
  • e30austin
    • 15382
    There are minor differences, between early and late model transmissions, but that doesn't make a difference how any of it bolts up.
    My guess is, whoever did the job, didn't change any of the bushings or the joint on the back of the trans.
    '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
    • ForcedFirebird
      • Feb 2007
      • 8300
      ...or they used an early shifter plate that always has slop, even when new, and is horrible once worn...
      john@m20guru.com
      Links:
      • wworm
        • Dec 2016
        • 1719
        can confirm plate style shifter being awful. Trying to make it better this week and feeling like it's just not going to be good. Don't have the tabs to convert it to late style either.
        1984 Delphin 318i 2 door
        • ForcedFirebird
          • Feb 2007
          • 8300
          I have seen many times where people use the flywheel backing plate cut in two pieces and bent to hold the shifter. Been a long time since I have seen one of those threads here, but probably could find it in a search.
          john@m20guru.com
          Links:
          • e30austin
            • 15382
            Change the shift joint, on the back of the trans, with a new one, from the dealer, and they are definitely tolerable. Not my favorite setup, at all, but it is what it is.
            If only, someone made a similar bracket, like BMW did on the E30 M3, to accept the later style, aluminum, shift carrier - but for a Getrag 260...
            • ainadude
              • Apr 2008
              • 221
              Can those components you reference be changed from inside the passenger compartment or does tranny need to be dropped?
              ainadude
              Indian Wells, CA
              • ForcedFirebird
                • Feb 2007
                • 8300
                Neither. You can reach around the drive shaft from underneath and change all the shift components.
                john@m20guru.com
                Links:
                • ainadude
                  • Apr 2008
                  • 221
                  Gotcha. Thanks, and Merry Christmas.
                  ainadude
                  Indian Wells, CA
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Same! Got a new laptop from one of the kids, and you can guess the first site visited once setup :p
                    john@m20guru.com
                    Links:
                    • ainadude
                      • Apr 2008
                      • 221
                      Score! Enjoy the day! :-)
                      ainadude
                      Indian Wells, CA
