1987 325e clutch replacement
  • rlydirty30
    • Feb 2020
    • 1
    the cps is on the bellhousing so im under the impression I need a dmf for the sensors to work, any suggestions on what to do would be appreciated
  • agent
    Vice Grand Pubaa
    • 7960
    General Discussion is not a catch-all; please do not ask technical questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
    Originally posted by kronus
    • tomstin
      • Mar 2015
      • 570
      I'm not sure what you are asking. On my 85, there are two speed sensors on the bell housing. I believe on looks for the teeth on the flywheel the other looks for a piece welded to the flywheel. The crank position sensor is on the front of the crank just below the alternator. Are you converting to manual from automatic?
      2004 525i Manual - 1985 325E Coupe Manual
      • TobyB
        • 5298
        Some etas had single mass, with the pins for the flywheel sensors.
        RealOEM can help for part numbers- but I don't know if it's 100% accurate as to which cars ACTUALLY got which flywheel.
        t
        single mass
