Auto Transmission Morning Sickness
  • g.ruff561
    • 1267
    My 1990 coupe automatic tranny is giving me fits. Transmission will not shift first thing in the morning. If I start the car and let it get to operating temperature, then drive around In first gear for a few minutes. Then shift to 2 then S then D. It will eventually catch and drive like a bat out of hell. I have to follow the same procedure every time the tranny cools down.
    Any feed back would be appreciated. Thanks.
    Be safe. Be blessed.
  • jeffnhiscars
    • Jun 2011
    • 6011
    I had "morning sickness" on an 89 cabrio when I lived in Charlotte. Standard diagnosis was either the governor or valve body. I had the valve body swapped and that solved it.
    Alice the Time Capsule
    • g.ruff561
      • 1267
      Leak appears to becoming from drain fill tube connection to pan. From what I have researched, there is no o-ring at that fitting. So how do I stop the leak. Any feedback would be appreciated. Thanks.
      • jeffnhiscars
        • Jun 2011
        • 6011
        Seems to me it's a flare fitting w a 22mm nut and it took a fair amount of tightening. As long as the mating surfaces are undamaged it should seal
