Help!!!Help!! Driveshaft
  • Amelbmw@aol.com
    • Mar 2019
    • 10
    I working on 1991 e30 swap auto to manual transmission
    my car is 91 and donor car is 1986
    question is:
    everything so far line up pretty good only driveshaft that come off 1986 car center support doesn’t want fit
    can I install latest model driveshaft center support on older model driveshaft?
  • reelizmpro
    • 9558
    yes
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • ForcedFirebird
      • Feb 2007
      • 8300
      Yes. and in fact, if the bearing is in good shape, you can change the CSB carrier/housing and leave the bearing attached to the drive shaft - the rubber mount/metal slides off the bearing. So, just slide the two CSB carriers off the auto and manual shafts and put the early metal ring on the manual shaft bearing.
      john@m20guru.com
      Links:
      • Amelbmw@aol.com
        • Mar 2019
        • 10
        Thank you !!!
