LSD Differential internals!!
  • Mhigh
    • Oct 2018
    • 9
    Hello there! I have some questione here, I hope someone has answer for me
    So the thing is since i Turboed my car i want to get longer diff ratio!
    Right now i have an LSD 3.91 (if i remember right) i have 2.79 i understand that it ring and pinion will not fit to my 3.91, so one thin is in my mind, i will not buy one more LSD diff but i culd buy only High offset LSD carrier the questione is will the Standart offset carrier internals (Discs clutches etc) will fit in High offset carrier withouth problems??
  • Vincenze
    • Apr 2019
    • 1046
    I believe that parts for differentials with the ratio < 3.15 do not fit into differentials with the ratio >= 3.15.
    • Mhigh
      • Oct 2018
      • 9
      Hmm interesting i actualy dont see why they dont fit!!?? cuz the carriers are the same size only difference is the rings attach in different hights!!
      • iman53
        • Sep 2016
        • 47
        I don't know it for a fact but I don't see why everything wouldn't fit the same inside the carrier. There's no difference for upgrading or replacing clutches between the two carriers so I feel like they would be interchangeable.
        • Vincenze
          • Apr 2019
          • 1046
          The LSD unit itself is interchangeable between 188mm differentials. I'm not 100% sure, though.
          I mean this thing.
          You should be able to remove it from one differential and move to the other.
          Then, you can install a different ring & pinion with the ratio >= 3.15 into any differential with the ratio >= 3.15.
          A different ring & pinion with the ratio < 3.15 can be installed into any differential with the ratio < 3.15.
          Of course, when they are 188mm.
          But it's better to sell your existing differentials and buy a differential with the ratio you want. It's very difficult to adjust a differential without experience.
          What ratio do you want?
          You can also use Z3 differentials, though, they are Torsens.
          • Mhigh
            • Oct 2018
            • 9
            I mean this thing.
            Yeah i know that 188 units are interchangeable, i was actualy meaning the parts in unit itself Discs Clutches Spider gears etc To move from Standart carrier to High offset carrier and vice versa!
            I need a 2,79
            • Northern
              I like cupcakes & sh!tboxes
              • 5288
              The LSD complete unit will not fit, but the guts from a high offset will fit in a low offset (assuming the carriers are both for LSD)
              The difference is just the carrier and carrier cap. I don't think you can put LSD parts in a non-LSD carrier, otherwise I spent a lot of money for nothing...
              Originally posted by priapism
              Originally posted by shameson
              • Mhigh
                • Oct 2018
                • 9
                thanks allot, yes i mean between LSD carriers yes! Mine is standard so i will go for High offset and just swap internals!
