thump thump thump...wtf is that?!?
  • EricT
    • 702
    Hey all. I'm rather new to the e30 world. I've got an 86 325es with a manual tranny. For the last couple weeks I have noticed while I am leaving a stop sign or traffic signal...if I press the go pedal any harder than granny speed I get this thump thump thump comming from the floor. So long as I baby the go pedal to get up to speed it doesn't do it....its only when taking off from a stop or I suppose when I put alot of strain on the driveline like going up a steep incline in any gear with low rpms...... I recently had tires replaced and happened to peek under the car while it was in the air on a lift. The guibo appears to be fine, no tears or cracks or loose bolts etc...turned the driveshaft by hand to check for play in the u-joints and they seem ok....didn't think to wiggle it at all but I'm thinking its possibly the center support bearing. Was just wondering if there is anything else I should check whislt I am under there this weekend poking around should the center bearing happen to check out fine....
    Thanks in advance, Eric
    BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Guibo/CSB, or halfshaft. That would be my guess.
    • Fidhle007
      I can fly, motherfucker
      • Oct 2005
      • 7209
      Csb.
      '89 325is S50 Track Montser
      '04 X5 Daily/Tow Vehicle
      http://www.avarestoration.com
      http://www.myspace.com/brendanfiddle
      Click here if you want to be my zombie slave...
      http://www.youtube.com/user/Fidhle007
      • Liam
        • 753
        Originally posted by Fidhle007
        Csb.
        Check your U joints while you're at it.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Fancy meeting you here. :)
          • atomic
            • Jun 2007
            • 5691
            Dead cat wrapped around a half shaft?
            • Liam
              • 753
              Seen rabbit jerky in there before, but no cats.
              Yep.
              What better way of spending the precious moments of your life than helping out the DIY with these "once fabulous wonders of engineering" now that they have become decades old rattle traps?
                That is a classic description of a failed Center Support Bearing (CSB). A failure of the CSB is almost always the result of binding drive shaft u-joints. So replace both.
                • EricT
                  • 702
                  I did check for critters......actually had that happen before...but that was in my dakota and it was a possum...not a cat.
                  • Jean
                    • 18228
                    Like many have said, bad u-joint and/or csb. Bad flex disc on it's own won't cause this, but could be ruined in the process...
                    driveshaft jobs suck ass.
                    • EricT
                      • 702
                      That they do. The sheer anticipation of taking the heat shields off keeps me awake at night.......anybody ever umm.....just forget to put them back on????? I mean the 1 or 2 lbs would be a gain if you count it as weight reduction right?????
                      • Jean
                        • 18228
                        Taking the heat shields isn't the big deal, I would also put them back on to protect the driveshaft from the elements etc...
                        It's the exhaust you'll have to drop to get to the driveshaft etc. Now would be a perfect time to order new shifter components to get them replaced at the same time, you'll have a nice and firm shifter. If it's all original, it's probably worn the hell out.
                        • EricT
                          • 702
                          The shifter is rather sloppy. Sounds like a plan. Think I'm just gonna go ahead and replace the u-joints, csb, and the guibo. Prolly get the stuff for the shifter too then. Yeah I just put an exhaust system on there and tucked in tight to the heat shields. YIPPEEE!!!!! It shouldn't be that bad. Thanks for all the input everyone.
                          • Liam
                            • 753
                            Yes, don't leave the heat-shields off. One bad effect from this is warming up the fuel tank and it will also bake the drive shaft especially after parking the car hot.
                            • EricT
                              • 702
                              I will be sure to re-install them.
