The u-joints aren't usually something you can just replace on these driveshafts.
thump thump thump...wtf is that?!?
Originally posted by Jean View PostThe u-joints aren't usually something you can just replace on these driveshafts.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
Originally posted by EricT View PostIs that right......well......what may this task involve? It's not like the typical pop the old ones out and reinstall new ones...just make sure everything goes back as it was? I havent really looked at them that close.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
I c...That sucks. Sounds like a gov't job at work then. I'll bribe one of the machinists with cupcakes to do it for me. I am just a feeble maint. mechanic. Basic machining I can do....if its really involved...thats what they are there for. Shit...I just recently wired up a hot tub for the one dude...he owes me a favor.
BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
i am having literally the same exact problem.
i plan on pulling everything off of a parts car that i know of.
how do i check if everything on the parts car is good?
and can i get pictures or some sort of diagram on exactly what i need to replace? that would be amazing.selling my cars
sigpic-BMX and Sideways vehicles-
Smoke tires, not meth.
well this is going back just a little.. but when i replaced my csb i couldnt get my exhaust off cuz i couldnt crack the rusted bolts off the headers so i lowered my diff and slid the shaft out from that rear subframe.... if that helps with anyone, it's what i did and it was pretty easy
oh and as of before taking the two halfs of the driveshaft apart.. mark it with white-out or something! it'll save u a big headache about worying if u put the two halfs together and they arent lined up properly.E30 LS1 swap, Tremec TKO, three link live axle rear suspension.
