M60 Swap thread
  • OrganicMechanic
    • Jan 2008
    • 1719
    #151
    in process
    join the E30 Cabrio owners gruppe
    click here for details
    • bmwmech1
      • Jun 2010
      • 1075
      #152
      Originally posted by OrganicMechanic
      in process
      Uh oh... another E30 V8... sweet!
      Garey
      • e30s50dan
        • Nov 2008
        • 2076
        #153
        Subscribed. Iwas at favorite junk yard last year to pick up a 4.0 and the sun of bitch crushed all the cars. Many 5 series,couple 3 series. Damnit:(
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • BruceBe
          • 108
          #154
          Originally posted by BruceBe
          That is a very useful swap part. With two -10 AN Aluminum bungs welded to it, that plate is a slick take-off to a remote filter/cooler. I was going to either tap the block, or build my own plate with O-ring'd counterbores, but this is easier and less expensive.
          Thanks for the info guys,
          -Bruce
          I've attached a photo of the modified X5 part, with -10AN bungs welded to it. This will make it trivial to install a high-performance remote oil filter, and ditch the stock, heavy BMW filter housing. And since the plate bolts on, the block remains unmodified.
          -Bruce
          • bmwmech1
            • Jun 2010
            • 1075
            #155
            -Bruce
            Wow Bruce! That's a pretty slick mod to that part! I still may just tap the block for mine to run a remote filter setup, but in your application this is right on the money. Nice motor mount, as well. Still waiting to get mine back from the duplicator(Jean), Lol! Any new news on the clutch/pressure plate front? Keep the pictures coming...
            Garey
            • BruceBe
              • 108
              #156
              Garey - I do now have a collection of parts that I believe will work with the JBR e39 flywheel, which means it will work with any stock e39 flywheel. However, until I have it all installed and tested, it wouldn't make sense to endorse it. If it does work, the good news is that the vehicle application for the PP/clutch is a common one.
              Not trying to be coy, I just would hate for anyone to go spend money on parts based on a recommendation that hasn't been verified/tested. Hopefully, I'll have an answer over the next few weeks.
              -Bruce
              • bmwmech1
                • Jun 2010
                • 1075
                #157
                -Bruce
                I respect that approach, Bruce. I'm not in any hurry, since the car is still in pieces anyway. Fingers crossed it works as you expect and we can benefit from your experiments. Post more pics, please, Lol! Unless you don't want to give away anything , since it is a track car...
                Garey
                Garey
                • Jean
                  • 18228
                  #158
                  I like that modified x5 part, pretty sure I'll just go with that as well :)
                  Garey - couple more days and they are back in your hands :)
                  • bmwmech1
                    • Jun 2010
                    • 1075
                    #159
                    That's cool Jean, just had to razz you a little, Lol! I like Bruce's piece, as well... maybe I'll do it too. Since my motor is completely disassembled, though, I may just tap the block...
                    Garey
                    • mkcman17
                      • Jul 2010
                      • 8240
                      #160
                      Seems like some nikasils actually dyno better too... it's probably a none issue at this point as well.
                      Anyway, I looked at some 300mm.de stuff, and will try going this route. Looks like the just cut/modified the stock driver side mount to make room for the e30 mount.
                      and the passenger side
                      http://www.300mm.de/typ5/05.jpg
                      did you end up going this route? i'm starting to finally collect for my swap and i didn't see how you ended up on the mounts.
                      1989 LN106 Hilux / 3.0TD SFA
                      1974 2002tii / stock
                      2002 IS300 / 5spd LSD
                      • Aleksey
                        • Feb 2011
                        • 336
                        #161
                        Sorry guys I'm a bit late on this thread, are you still looking for mounts? I might have a contact in Germany that can provide a complete mounting kit for M60 on E30 frame.
                        Founder @ Maintenr. Take control of your vehicle maintenance.
                        • mkcman17
                          • Jul 2010
                          • 8240
                          #162
                          quality, price, link?
                          • bmwmech1
                            • Jun 2010
                            • 1075
                            #163
                            I didn't answer this right away... I thought I'd let Jean post a reply, but since he hasn't yet... I made the mounts Jean is using. He "borrowed them a while back from me to use as patterns to fashion his own. His fab guy is not the fastest fabricator, as he's been at it for a few months. Chances are, he works on them in his spare time, which may not be much, Lol! Jean has promised I should have the mounts back soon, as I'm getting closer on my build to needing them. They're not difficult to make, I copied the idea from the ones Jonsku made, which are the ones that are for sale. They're pretty salty, pricewise, which is why I just made my own. Jean and I were talking about our swaps, which were going on simultaneously, and asked if he could use mine to pattern his and I said sure...
                            Garey
                            • Aleksey
                              • Feb 2011
                              • 336
                              #164
                              I will ask my friend tomorrow if I don't forget
                              • bmwmech1
                                • Jun 2010
                                • 1075
                                #165
                                Should have everything you need to know...
                                Garey
