E30 S62 Vert
    E30 S62 Vert
    Hi all.
    Thought i`d share some knowledge on the brakebooster issue.
    From my own project.
    H31 system from E32 w. ABS
    You know it. Euro E30´s rule.
    Jesper K.
    sigpicJesper K
    E39 TOURING TDS
    E30 325i VAN
    E30 350i VERT
    Thanks for sharing, a fellow 1uz E30 swapper is using that set up in Netherlands due to the space it offers.
    Looking forward to more on the 350i Vert.
    p.s I hate you for having S62 :p
    Originally posted by der affe
    first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
    if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
      Yap, that's a good system though needs bit more plumbing.
      More pictures of the swap would be nice, will it be up'n'running this summer? :)
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
        Great to know! thanks for posting, I'm starting on the same swap here in a few weeks.
          I'm just here to subscribe to the S62 awesomeness.
            Awesome--any more info on this booster setup? Looks like it uses pressure from the PS pump--did you custom make lines?
            Some brief info and a teardown of the H31 booster:
            paint sucks
              This could be crazy useful. Any s## motor in an e30 is slick! Especially one that big!
                Yep, and no crazy remote or boosterless setups or anything. :p
                paint sucks
                  Interesting - a few questions:
                  1) Has anyone successfully installed this system and road-tested it? I'm curious as to the MC diameters/interchangeability.
                  2) Which PS pump is being used? Conceivably, you could utilize a later tandem vane pump with an ABS port, right?
                  3) What are the cost-effective donor car options here in the USA?
                  Thanks for sharing.
                  -Bruce
                    Im trying to find Marcels more comprehensive thread, this is the fellow in Netherlands that has the 2jz with the hydro set up, will keep searching and post up when i find it
                    Great guy, and is also building a 1uz E30 like mine
                      Here is his thread on e30t3ch http://www.e30tech.com/forum/showthr...t=74338&page=3
                      Somewhere he has a thread where he goes into more detail about the brakes, on a supra or 2jz forum in netherlands,
                      Just PM him on e30t3ch, Marcel is a great guy
                        H31 hydrobooster
                        Hi all
                        The supply pump seems to be an ordinary P.S.-pump.
                        The regulator/accumulator unit has an output for the P.S.
                        Jesper K
                        sigpicJesper K
                        E39 TOURING TDS
                        E30 325i VAN
                        E30 350i VERT
                          Bump for updates
                          E30 buildy things
                          http://www.r3vlimited.com/board/showthread.php?t=195286
                            Originally posted by Jesper K View Post
                            Hi all.
                            Jesper K.
                            How much clearance actually is there between the booster and the cylinder head or coil cover? Looks like less than 1" (25mm)...
                              .. which is already enough :)
                              - E34 M5 (x 2) -
