Some E30 V8 videos
  • dude8383
    • Jan 2005
    • 10387
    Originally posted by bmwmech1
    Jean, you can bolt the short block to the subframe and drop the car over it, then bolt the heads on from the top. That will work fine. My suggestion, although a little more work is to make your core support removable. Then you can slide the entire assembly in from the front. Remember that separating the trans from the motor while its all in the car will be damn near impossible. Having the core support removable makes installing/removing the motor/trans very simple. I slide mine in by myself in 15 minutes, no lie... the whole motor complete and the trans together. Very easy. Just my 2 cents...
    Garey
    How difficult was it to make the core support removable? Don't won't to get off topic here shoot me a PM if you don't mind sharing!
    • Texas Toast
      • Jan 2011
      • 510
      I'm interested in this also. I've got a motor lined up and hoping to start this summer. These videos are getting me motivated!
      Wrecking cars, closing bars.
      Tie rod spacers for sale: http://www.r3vlimited.com/board/showthread.php?t=245785
      • Jonsku
        • Oct 2004
        • 566
        Jean; the VAC 600hp monsters are racing-engines, rebuilt very often :) But yes, as you said extracting another 100hp with e.g. 10% capacity increase and some head work shouldn't bee too hard a task. The camshafts would need some attention too, though custom camshafts / aftermarket ones are damn expensive..
        Making the front "detachable" is not too hard task, there're lots of examples at e.g. www.pure-pf.com and e30zone.net - it's basically just four bolts that keep it all together instead of point welds..
        Sorry for the OT! :)
        - E34 M5 (x 2) -
        - E30 V8 Cabrio "Kylpyamme" -
        - Alpina D10 Touring #33/94 -
        - E46 318i Touring -
        - Toyota Hiace 4wd -
        • Jean
          • 18228
          Yeah, I only mentioned VAC to show the "potential limit" in a way. Of course those engine probably don't last very long.
          Since there are 4 cams , will be more expensive than I6 engines simple because you've got 4 cams vs 2 but I think the price per cam is still about the same?
          I'll have to consider modifying the core support, I'll have to check the rule book and make sure that's not something that isn't illegal in the class I'll be in.
          • Mullet Bullet
            • May 2011
            • 904
            ive been thinking of a v8 swap for a little while now since they are so cheap at the local wrecking yards, maybe its time for some more research.
            Originally posted by nwvb bmw
            That guy is going to lock you in his basement and make you ware a little pirate costume.
            • bmwmech1
              • Jun 2010
              • 1075
              Oh yeah, I forgot about yours being a track mule... that may not work in your situation. Hopefully it's okay in your regs... it makes life way easy! OK, back on topic...
              Garey
              • The Dark Side of Will
                • Jun 2010
                • 2796
                Mental note: need to make core support removable when the time comes.
                I'll have to take a look at it, but my mind wanders to the possibility of fabbing up a heavier version to reinforce the famously unstiff E30 body.
                • JGood
                  • Jan 2004
                  • 7959
                  I currently have my front end torn apart, and it's amazing how flimsy some of the core structure is, without some of the surrounding sheet metal attached. You'd think those frame rails would be solid, but with one finger I can flex mine up and down a good 1/2", just because the strut housing is removed.
                  Just stitch welding everything and adding the Vert weld-in reinforcements would do wonders, but fabbing up a new rad support would be very worthwhile for a track car IMO.
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • bmwmech1
                    • Jun 2010
                    • 1075
                    Originally posted by JGood
                    I currently have my front end torn apart...
                    Yeah, I'd say... are you doing rust repair? I though I saw some WTB posts from you about donor sheet metal...
                    Garey
                    • JGood
                      • Jan 2004
                      • 7959
                      Garey
                      Yeah, documented here: http://www.r3vlimited.com/board/showthread.php?t=225093
                      I PM'd you about stopping over some time. I think my buddy Jared (Too Short) also talked to you a while ago about stopping by to check out your project. We'll have to set something up some time. This way I don't have to reinvent the wheel several times, as I plan on doing many of the things that you have already done.
                      • c4ls7
                        • Jan 2010
                        • 97
                        found one to add
                        94' 6speed 383 LT1 Corvette 450rwhp 450rwtq
                        :!:91' Alpine 318is - under construction
                        • JGood
                          • Jan 2004
                          • 7959
                          I love this one, the echoing V8 sound as he comes around the corner in the beginning, then at :20 he pulls away slow in first gear, shifts into 2nd at a low RPM and rolls the tires like it's nothing.
                          • bmwphatpat
                            • Aug 2011
                            • 66
                            Here's a couple aurally pleasing vids I've enjoyed recently
                            Enjoy! :D
                            • einarsss
                              • Apr 2007
                              • 101
                              Sorry, we couldn’t find that page
                              E30 3xxi - BRILLANT ROT
                              • einarsss
                                • Apr 2007
                                • 101
                                Playing around with Bmw E30 M5 V8 Compressor, let it be smoke..
                                E30 s62 compressor tire burning
