E30 M3 S62 Build - Loads of queries about 4x4 drivtrains
Looks like the rear output is on the drop rather than centered.Comment
yes think youre right!!!Comment
Since the Getrag 265 has a removable bellhousing, you could use an auto trans bellhousing for the M60 and mill an adapter plate to bolt the 265 to it. The 265 has a rear case section similar to the rear case of the 260, with an abundance of bolts close to the back of the trans. You could either weld something to the 265 rear case or machine something to bolt up to the case bolts that are already there.Ratio wise I don't think i will be able to put up with 5 speed. I definitely need overdrive as i will be doing a fair bit of mileage and want to have a nice low cruising ratio.
I certainly wanted to be able to utilise the m5 6 speed. Back to the drawing board.
This is what I have so far btw: an ix subframe and x5 sump, Im looking for a scrap v8 block to bolt up temporarily for measuring etc.Comment
That box is still 5 speed only though isn't it?Since the Getrag 265 has a removable bellhousing, you could use an auto trans bellhousing for the M60 and mill an adapter plate to bolt the 265 to it. The 265 has a rear case section similar to the rear case of the 260, with an abundance of bolts close to the back of the trans. You could either weld something to the 265 rear case or machine something to bolt up to the case bolts that are already there.
I do have a s14 with one of them bolted to it but it's my daily driver so can't really butcher it.... Yet.
I'd still rather find something non electronic tcase wise and get some mounting points welded to the m5 6spd.
I have been looking at ford ranger pickups tcases and alike but it's very hard to get an understanding of what its like from web pix.Comment
It is a 5 speed, but it has an overdrive unlike the ZF. Its overall ratio spread is close to that of the 420G. It's also very robust. The "normal" 265's have a 3.83 first gear and .81 fifth. I've heard that the versions used in the E30 M3 had a 3.38 first gear instead, but have not confirmed. Note that I am *NOT* talking about the dogleg box.Comment
Is that the same box that came in the old opel gsi's and some jags?
I have been looking around for one and they seem to be few and far between, and if they are around they're pricey! In terms of extending the centre shaft and choice of clutch/flywheel combo what would you suggest ?
cheers
turkComment
*subscribed
Auto Technic J-Stock Suspension Kit, Bilstein Shocks and Struts, ST Sway Bars, Front Camber Plates, Offset Euro Upper Strut Mounts, Chassis Reinforced, Aluminum Rear Shock Mounts, Offset control Arm bushings, Custom Control Arms, Custom Springs, Conforti Chip, UUC Ultimate Shift Kit, Kosei K1s, Sabelt 5 Point Race Belts
In the US, we can check www.car-parts.com for used parts. It's a database to which junk yards upload their inventories. It's pretty easy to check for a transmission for a '85 535i. I bet there's a similar service in the UK and/or Europe. I learned enough German to fumble through something like that for Germany, but it wasn't automated.Is that the same box that came in the old opel gsi's and some jags?
cheers
turk
You might try checking with the local breaking yards to see if they have a locator service that they use.
Here's an application chart for 265's:
Blurb about Getrag 265 applications:
thats brilliant mate, many thanks. They're a bugger to find though.Comment
Any Idea what the T-case designation for the E34 is?drivetrain components are still rated by torque, not horsepower.
http://boards.bmworg.ru/viewtopic.php?t=2835Comment
right I have found a 5 speed american type get rag out of a US M3 (non dogleg) just chatting money with the guy. This begs the question now as to what flywheel and clutch to use? Will the centre shaft reach?Comment
Can anyone supply me with a part number for the Bmw v8 Bellhousing? I have been searching online and realoem and just can't find it.
Cheers
TurkLast edited by Turk; 02-25-2012, 08:24 AM.Comment
Don't know the part number... I just looked on the locator for a bellhousing for a '98 540i. You'll need the OBDII bellhousing because of the crank sensor low on the right side.Comment
