Is that ceramic coating or just paint?
MMP M62B44 Build Project "Jack-N-Coke"
No real update today..
Motor installed for last time...
Clutch line hooked up and bleed, shifter linkage installed.
Pulling Diff this weekend to rebuild and install Z3 cover... :nice:
Harness almost finished...
working on intake and air box now.Last edited by MonkeyMadness; 08-29-2013, 08:39 PM.https://www.forabodiesonly.com/mopar...re-irs.356333/
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.Comment
Nice dude!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
I just spent 2 hours reading every updated n reply you got on this...... I hope to get a ride when this is all done im so exited keep up the great job MMP out :)Comment
Wow, that is a really elegant solution to a long standing problem! Nice work.
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
What would it cost me to have my water crossover pipe modified? I'm in Fairport, NY (14450.) Thanks!sigpic
Velocity Motor Works
1972 2002
1983 533is
1987 325is (Roxanne)
1988 M6
1989 M3
1989 325ix (Darth Maul)
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...Comment
So, finally had time and the needed info to get back to project Jack-N-Coke
So today i installed the Garagetastic tach mod for the V8 swap.
Decided to mount this on the "blue c1" plug off the back of the cluster. Keeping in the cab, away from harm.
So if your interested in doing the same I'll post up the info below.
Blue C1 connecter
Soild brown = Negative/Ground
Grn/yellow = 12v/Positive
Pin #7 solid black splice this in dme to tach
Yellow to tach , white to dme.
Remember Garagetastic's mod requires a 4cyl tach plug. This mod will not work with the 6cyl plug
You'll need a Dakota Elc. Setup for the 6cyl.
After shrink rapping it and zip tie-ing it it the wire harness it is now protected and hidden
:beer:https://www.forabodiesonly.com/mopar...re-irs.356333/
Need what from Dakota Electronic ?So, finally had time and the needed info to get back to project Jack-N-Coke
Blue C1 connecter
[ATTACH]77077[/ATTACH]
[ATTACH]77078[/ATTACH]
[ATTACH]77079[/ATTACH]
[ATTACH]77080[/ATTACH]
:beer:
ThanksComment
The Dakota Digital SGI-8. It's a fully programmable unit, packaged in a nice little box, works to translate any # of cylinders. It's only $80, I don't understand why more people don't use it, vs paying $20 more for a non-packaged board that requires a specific coding plug. I guess size is one thing the board has going for it...Comment
True that. I do agree for the most part...The Dakota Digital SGI-8. It's a fully programmable unit, packaged in a nice little box, works to translate any # of cylinders. It's only $80, I don't understand why more people don't use it, vs paying $20 more for a non-packaged board that requires a specific coding plug. I guess size is one thing the board has going for it...
I chose it for a few reasons.
1. I already had the coding plug
2. Size, this was a large part of it
3. Corny as it may sound, it keeps the money in the community (e30) helps out a local e30 parts supplier.
Plus I'm a cheap bastard. If i can build it i would rather than buy it every time. But if i can't then i have no problem spending the extra money on a good product. :)https://www.forabodiesonly.com/mopar...re-irs.356333/
Thanks MM / JGood.^^^^^
I've looked at tach signal unit on Summit.
I didn't get the connectionComment
Very valid reasons, and I agree 8-)Comment
Sorry
