MMP M62B44 Build Project "Jack-N-Coke"
  • Vtec?lol
    • Dec 2009
    • 3278
    #271
    Originally posted by MonkeyMadness
    Did you cap off the line or just leave it open?
    It should vent to atmosphere. A small filter would be best.
    Originally posted by The Dark Side of Will
    Unless you go to throttle per cylinder, you'll spend the rest of your life tuning acceleration enrichment.
    I agree on Alpha-N.
    With my GM background, I like MAF over MAP, but last I heard, MS doesn't do MAF very well.
    Originally posted by ForcedFirebird
    False.
    Originally posted by Wanganstyle
    True alpha n NA is silly; and = digital carbs.
    MAP sensor + na = best.
    I should have said, " I can't run 10lbs on the stock ecu without myself blowing it up"
    ITB's would be the goal. Else wise I would just stick to the factory setup.
    With boost it would be MAP.
    • MonkeyMadness
      • 3251
      #272
      woohoo! quick update... I get my supercharger convetion parts tomrrow!
      I will be able to mock up my SC build...! :nice:
      • ForcedFirebird
        • Feb 2007
        • 8300
        #273
        If you cap it, fuel will shoot 6' from the filler when you open it. Just loop the line 180 degrees and make sure it's higher than the full level of the tank.
        Still false. I have personally tuned Motronic 1.3 well over 10psi. Porsche 944 turbo used Motronic 1.1 from the factory.
        w00t!
        john@m20guru.com
        Links:
        • LoneWolf
          • 402
          #274
          w00t!
          I thought the m60 ecu was 3.3 dme? Not 1.3.
          • ForcedFirebird
            • Feb 2007
            • 8300
            #275
            Doesn't matter. They can be tuned for boost. There's even public definitions for the m60 available on TunerPro.
            /thread derail, sorry Jeremy.
            john@m20guru.com
            Links:
            • Northern
              I like cupcakes & sh!tboxes
              • 5281
              #276
              Very interested in a pnp whodwho ms3x for m6x engines as well.
              My m62tu did not come with a dme, or pot pedal, as well as other stuff. It seems to be cheaper to go ms3x than buy everything, get ews flashed, and then be limited to the drive by wire setup/intake that the engine runs from the factory
              Originally posted by priapism
              Originally posted by shameson
              • Vtec?lol
                • Dec 2009
                • 3278
                #277
                Thanks for the info. But I could've sworn the 3.3 was non-flashable. Any links to more info? Sorry to derail.
                • MonkeyMadness
                  • 3251
                  #278
                  OK so welded up the silencers on my m112 body..
                  than mocked up what it should look like when finished. Even at this point i am about a 1/2 to 5/8's to tall to what i want the end result.
                  • MonkeyMadness
                    • 3251
                    #279
                    [ATTACH]80852[/ATTACH]
                    [ATTACH]80853[/ATTACH]
                    [ATTACH]80854[/ATTACH]
                    [ATTACH]80855[/ATTACH]
                    [ATTACH]80856[/ATTACH]
                    • MonkeyMadness
                      • 3251
                      #280
                      [ATTACH]80857[/ATTACH]
                      [ATTACH]80858[/ATTACH]
                      [ATTACH]80859[/ATTACH]
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #281
                        Blown arrow V2.0?
                        :D
                        john@m20guru.com
                        Links:
                        • MonkeyMadness
                          • 3251
                          #282
                          Originally posted by forcedfirebird
                          blown arrow v2.0?
                          :d
                          hahahaha...
                          [ATTACH]80861[/ATTACH]
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #283
                            hahahaha...
                            YESSS! How we met so many years ago :P
                            Carry on my man, excited to see this beast come alive...
                            john@m20guru.com
                            Links:
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #284
                              • MonkeyMadness
                                • 3251
                                #285
                                Sorry, it was just a late night internet bro' hug... lol
                                Sent from my LG-LS970 using Tapatalk
