MMP M62B44 Build Project "Jack-N-Coke"
  • MonkeyMadness
    • 3251
    #121
    So got some cool CONDOR parts into day...
    Steering Delete:
    New M3 Solid bushings rotated 90* to compensate for the 10mm drop spacers on the Crossmember. I noticed that after the spacer install the rubber bushing were under a sizable twisting load, compound that with the normal road movement of the suspension. This worried me So I got a set of M3 solids and rotated them 90* down.. Worked like a charm...;)
    And some pic's of the rad and mounts
    Starting to really get excited about this project.. Still have a lot on my plate with other cars here at MMP but man this is fun! :up:
    You have to check these guys out! Super Nice and Awesome Group! :nice:
    • MonkeyMadness
      • 3251
      #122
      Valve covers off and on there way to Robertk for some MMP liver tomorrow!
      • silence
        • Jun 2007
        • 1824
        #123
        Looking good!
        Ingenious use of the offset CABs!
        •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
        •• Rear Subframe Bushings • RTABs • Facebook ••
        • MonkeyMadness
          • 3251
          #124
          Only update for now!
          Sent from my LG-LS970 using Tapatalk 2
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #125
            Originally posted by MonkeyMadness
            Steering Delete:
            [ATTACH]64890[/ATTACH]
            I'm not sure that's such a good idea. You'll probably need steering at some point... ;)
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              #126
              I like the idea of rotating the CABs to compensate for the spacers. Nice!
              • MonkeyMadness
                • 3251
                #127
                So pukled the bottom pan to check the oilpump bolts before I button everything up with the trans.
                To my surprise when I got in there everything was tight and torqued to spec. :up:
                • MonkeyMadness
                  • 3251
                  #128
                  Just a small update!
                  Just finished the M42 2002 swap and it has gone home .
                  So I'm back on the V8
                  So I just ordered a DME 284 to cloth my MS3.
                  then I bought one of these
                  E30 V8 rpm module
                  Your factory RPM gauge will not be accurewhen you do the conversion. The DME signal must be modified and a 4 cyl BMW coding chip must be used. We offer a "RPM signal modifer" or as we call it, a RPM module. Simply wire it inline and your RPM gauge will be accurate. Needed for any v8 swap in an e30.
                  Click here to buy RPM module separately or include in your own e30 m6x swap kit.
                  Features:
                  - Fully tested and professionally built
                  - 10 min install
                  - Allows use of factory e30 tach in v8 conversion
                  - 4 wire install
                  Each ROM module kit includes:
                  RPM module
                  Instructions
                  • Jean
                    • 18228
                    #129
                    What radiator is that, not e28 535i is it?
                    Pull the cover, replaced the guides?
                    • MonkeyMadness
                      • 3251
                      #130
                      Yes it's the same radiator used in the RTSAuto.com build.
                      I inspected the rails and found little to no wear!?! O_o
                      and the cover gaskets and timing chain look to have been replaced.
                      I don't know the milage of the motor, but it looks to have been taken care of.
                      Now that I got the DME today I'm working on the harness and have a few questions mostly identification of plugs.
                      Mostly need to identify the EWS plug and trans plugs.
                      First off is the plugs near the Dme. I have no clue what these are, plus do I have the plugs in the DME right, thought the blue plugs are trans plugs please help...:eeek:
                      • MonkeyMadness
                        • 3251
                        #131
                        Now for the pig tails.
                        I'm sure these are the trans, crank/flywheel trigger plug,
                        Full big tail off the back of harness
                        I think this is the left side O2 sensor and the crank/flywheel trigger plug
                        I think this is the right side O2 sensor
                        Guessing these are for the transmission
                        • Jean
                          • 18228
                          #132
                          IIRC for O2 sensors, as the M62 has 4 of them i think, pre/post.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #133
                            Definitely o2 plugs in the last 2 pics.
                            john@m20guru.com
                            Links:
                            • MonkeyMadness
                              • 3251
                              #134
                              Ok so changed my plan of attack,
                              First off I finished painted and did the final bolt in for the pedal box
                              all brackets and mod are bullet proof, this is really starting to look fun... :p
                              ok for the change. I got my dme 284 last week and have had a hell of a time finding a pinout for it.. ugh
                              So i ordered an full harness and Dme 404 from a 95 M60b30
                              info all over the net on this setup pinouts mods what ever.
                              MS3 here we come!
                              As for the conversion to the motor to run it, not a n issue...
                              planing of posting more pictures when things start moving along...
                              • TheTacoMan
                                • Nov 2011
                                • 2308
                                #135
                                Nice lotus!
                                Will you be dynoing with ms3?
