College kid M60 E30 (ongoing build)
  • MJCRO
    • Apr 2012
    • 597
    #136
    Pulled off the intake manifold tonight to get to the rear coolant housing and finish mounting my reservoir and coolant hoses. God I wish I had more money so I could swap an entire B40 intake setup to help make more power. I'm currently just working on finishing my cooling setup and deleting all this air pump and charcoal canister nonsense. I'm also waiting on these E39 525DTS motor mounts to arrive since my revshift ones are too low and the oil pan is touching the subframe.
    Also, check out this easy mod to get the oil filter housing out of the way combined with an eBay Z3 radiator. Made two extension brackets (one is visible in the picture above) to help tilt the housing away and give me ample room to fit my hoses. If you're wondering how my front hoses are set up, I'm using E34 530i hoses in the front that I cut to the length I needed and used two 1.47" copper pipe adapters just 3" in length to attach both ends. Cost like $5 for both at Home Depot, just check out the Plumbing aisle and you'll find a ton of stuff.
    • Vtec?lol
      • Dec 2009
      • 3278
      #137
      nice!
      • MJCRO
        • Apr 2012
        • 597
        #138
        Update: September 18th
        Been lazy to update my thread due to school but I'm in the process of fixing a couple of issues with the car. Had to order a larger bore for the clutch master cylinder from Wilwood yesterday because of issues with clutch not disengaging. I had ordered 5/8" thinking it would be large enough but I'm paying for it now. I'm going with 3/4" as Garagistic did in their swap. I'm working on shortening the harness and figuring out why my coolant temp gauge isn't working too. Also ordered a clean used ICV due to the car running rich and the engine dying when I cap off the vent lines on the intake manifold for the charcoal canister and brake booster.
        I'll have more pictures as I slowly get the car roadworthy.
        I was able to delete the air pump system the B30 had (emissions BS) and cap off this exhaust vent.
        I'm also running my coolant reservoir setup the same way FrankM did with his M60. I used all E34 coolant hoses with slight trimming of the hoses. Also had to massage the firewall in to reduce any kinkage of the rear heater core hoses.
        Haha for Frank, here's those exhaust shots you were asking about. Everything lines up perfectly.
        Copying and pasting this from my other thread but here's the size comparison between Revshift mounts and E39 525TDS mounts for people's future reference.
        For Garagistic's engine mounts, these are necessary. Revshift or any other M60 mounts won't work (that I know of). They're a huge improvement over Revshift ones. Vibration into the cabin is almost zero due to these having the softness of stock motor mounts. Clearance over the subframe and steering rack is nominal too (about 7cm).
        • slammin.e28
          שמע ישראל
          • 12054
          #139
          Awesome! Thanks for the comparison! I just got standard M60 mounts. Will have to get some TD mounts.
          • MJCRO
            • Apr 2012
            • 597
            #140
            My brother driving the car. Still need to get the car running right but it's pretty much ready for the road.
            • mbonanni
              • Sep 2011
              • 6236
              #141
              Needs more burnout
              • MJCRO
                • Apr 2012
                • 597
                #142
                Update: September 25th
                Fixed the issue where my car was running rich. Reset the ECU with all the plugs capped on the intake manifold. Started up perfectly and idles great now. Still surges a bit, but I still need to replace all the gaskets on manifold and possibly replace the ICV if the issue continues. In the future I'm planning on swapping out the B30 manifold and throttle body for an entire B40 intake setup. That combined with a chip, should be making close to 250HP at wheels according to some dyno sheets floating around the net.
                But SHE DRIVES and is finally ready for the road.
                Now I need to begin the process of tidying up things in the engine bay, putting back the front and rear ends back together and getting it registered. My 21st birthday is coming up next month and I couldn't be happier that I finished the car before then.
                Gonna have videos and pictures of the car once I get it presentable.
                • 36brua
                  • 689
                  #143
                  Great to see you're on the road !
                  Any info on what alum shifter arm and shift rod you ended up with?
                  I'm also using the ZF310. Thanks
                  My CA legal M60 swap
                  The happening in our garage
                  • Garageaholic
                    Freestyle Fabricator
                    • Dec 2005
                    • 5204
                    #144
                    Congratulations! Sounds great! Id just be careful on those numbers. I think you might be a little optimistic. 250rwhp is equivalent to 290bhp, which is more than a stock m60b40. I think you'd be hard pressed to squeeze that kind of power out of the 3.0L version, NA despite the charts that the German guy posted on bimmerforums.
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    Instagram.com/garageaholic
                    Youtube.com/garageaholic
                    • MJCRO
                      • Apr 2012
                      • 597
                      #145
                      Haha I can dream though, can't I. I'm happy with anything over 200 to the wheels.
                      Dude, when am I gonna get to see that beast of yours! I can't even imagine what it drives like.
                      • MJCRO
                        • Apr 2012
                        • 597
                        #146
                        Currently using the stock linkage that came with the transmission and modified it to fit my car. Down the road I might get something custom for a better feel.
                        • MJCRO
                          • Apr 2012
                          • 597
                          #147
                          Mini-update: September 26th
                          Finished bleeding the brakes, put back part of the front end back together, and Sea Foam'd the engine. I'll be addressing some small rust spots around the body and fixing those this weekend. Also, picking up some late model bumpers pretty soon and should have the car registered not too long after getting everything on.
                          • 36brua
                            • 689
                            #148
                            Thanks for the info. From what I've read It seems to be a bit of mix 'n match.
                            Your updates give me hope !
                            • ST1G
                              • Oct 2012
                              • 6689
                              #149
                              Awesome build mate, just read the whole thing. Can't wait to see this thing done.
                              I don't know how you have any time. I hardly have time to change my oil when I'm in full time school.
                              • F34R
                                sLaughter
                                • 12376
                                #150
                                Awesome meeting you yesterday, nice build you have going.
                                Instagram: @BWeissLeather
                                Current cars:
                                ~ '87 325 M30B35 swap
                                ~ '87 535
                                ~ 01 540 Msport 6spd
                                ~ '06 X5 4.8is
