College kid M60 E30 (ongoing build)
  • JGood
    • Jan 2004
    • 7959
    #106
    Originally posted by dirty30
    What you are supposed to do is get the DD shaft where you want it, mark the locations of the holes for the set screws then drill into the DD shaft 1-2mm or so then reassemble. The set screws are only there to keep the shaft in place not necessarily to keep it tight. There is a jam nut to make sure the set screw stays put also. The flaming river stuff is about as nice as you can get. The fit is beyond precise and the price reflects it.
    ^What he said
    I've had the Flaming River joints on my car for 1 year and 8k hard miles, not a single issue so far. I used loctite on the set screws and jam nuts, and drilled a notch for the set screw location as Ryan mentioned.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • Vtec?lol
      • Dec 2009
      • 3278
      #107
      It's a good I dea you got the pedals installed before you put the motor in. I recomend flushing the ABS and lines with fresh fluid and then bleeding the FACK out of the pedals. They are a pain in the ass to bleed. Hopefully you remembered to bench bleed first. Be prepared to take them out a few times to make proper adjustments
      • totheredline
        • Jun 2013
        • 762
        #108
        Love this. B30ftw. should be pretty rev happy.
        = Heidi 1988 325 -> 335i. 7200rpm built M30
        • MJCRO
          • Apr 2012
          • 597
          #109
          Updates coming.
          • alco
            • Feb 2013
            • 197
            #110
            So how's this going? Are you driving yet? I'm tempted to follow in your footsteps with the pedal setup once I get back into this swap.
            Velocity Motor Works
            1972 2002
            1983 533is
            1987 325is (Roxanne)
            1988 M6
            1989 M3
            1989 325ix (Darth Maul)
            Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
            • MJCRO
              • Apr 2012
              • 597
              #111
              Almost. The motor and transmission are seated in their final positions. I was just held up on updating this thread because of fuel lines that took a while to arrive from Germany. Just finished installing everything back together yesterday. Pictures up soon.
              • MJCRO
                • Apr 2012
                • 597
                #112
                Update: August 7th
                The car is inching it's way towards the road. Still need to pick up a few more parts, but I'm pretty much at the point where I can slowly begin to put everything back together and fire her up.
                Painted the engine and valve covers and did some required maintenance.
                Motor sitting in the rear most position.
                All new pre-bent fuel lines I waited over a month for. (Old ones were rusted through in some spots)
                Shifter linkage cut to fit E30. (ZF 310Z)
                Needed to purchase a manual transmission mount since the car was originally autotragic. (Bolts up perfectly, no modding required)
                Mocked up FrankM's exhuast setup I got off of him a while back, no issues whatsoever.
                • UpstateMike
                  • Jul 2013
                  • 218
                  #113
                  Man that is inspiring! I'm going to do a s52 swap and I thought that was going to be tough lol. You have your hands full there!
                  • MJCRO
                    • Apr 2012
                    • 597
                    #114
                    I'll just leave this here.
                    Updates coming soon.
                    • poopin04
                      • Jul 2010
                      • 1396
                      #115
                      Oh damn, IT"S ALIVE!!
                      Where'd you get your new hard lines from?
                      Click here to leave me feedback on our transactions. :p
                      • fanboi
                        • Sep 2012
                        • 136
                        #116
                        this was a very good update. congrats!
                        Odd man out
                        Vanos=Very Aggressive NOS???
                        • garagistic
                          • Apr 2011
                          • 1712
                          #117
                          Glad to hear its alive!
                          • MJCRO
                            • Apr 2012
                            • 597
                            #118
                            Thanks guys, I'm stoked! Currently in the progress of putting everything back together. I'll make sure to have some sweet pictures up soon.
                            @poopin04 The lines are from Autozone.
                            • UpstateMike
                              • Jul 2013
                              • 218
                              #119
                              Can't wait for the pix
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #120
                                Pre-bent and all? Impressive.
                                Now I've got the itch to work on my car.
                                Ugh. Lol.
