College kid M60 E30 (ongoing build)
  • MJCRO
    • Apr 2012
    • 597
    #121
    Pre-bent and all? Impressive.
    Now I've got the itch to work on my car.
    Ugh. Lol.
    You mean the fuel lines? Oh those I had to special order from the dealer. The brake lines I got from vatozone and had to bend myself.
    I've been following your thread, get at it! :p
    • alco
      • Feb 2013
      • 197
      #122
      What master cylinders are you using? I missed some of the details. Can you share? I will be using a similar setup in my car. Also what flywheel did you end up using? I recall you were looking to resurface one?
      Velocity Motor Works
      1972 2002
      1983 533is
      1987 325is (Roxanne)
      1988 M6
      1989 M3
      1989 325ix (Darth Maul)
      Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
      • MJCRO
        • Apr 2012
        • 597
        #123
        I used two Compact Remote Flange Mount Master Cylinders in 5/8" bore for the brakes, and 3/4" for the clutch, in combination with Garagistic's brake booster delete bracket. The write-up for that is located here.
        For the flywheel setup, I went with an OEM replacement from Luk for the M60B30. Part # 21211223508.
        • alco
          • Feb 2013
          • 197
          #124
          Thanks for the quick response man!
          1972 2002
          1983 533is
          1988 M6
          1989 M3
          • MonkeyMadness
            • 3251
            #125
            Damn kid good job, I'm still miles away from turning mine over...
            Excited to see the finish..
            • MJCRO
              • Apr 2012
              • 597
              #126
              Update: September 3rd
              On four wheels again!
              Got my E36 steering rack and big guibo 325e driveshaft installed. No more bus-like steering! Still need to hang up the exhaust, bleed the clutch, mount my cooling system and finishing putting back the interior together. Getting things done as parts arrive in the mail.
              The car is on Eibach Pro Kit lowering springs and Bilstein shocks for now but I'm in the process of getting coilovers. Also, I'll be doing a late model bumper swap in the upcoming weeks.
              I plan to take a crap of load of high quality pics of the car after I get everything put back together so it can stand as a reference for other people, but here's some from today after rolling it out to clean the garage.
              • Vtec?lol
                • Dec 2009
                • 3278
                #127
                does your pan touch the subfram or the rack at all with those revshift mounts?
                • MJCRO
                  • Apr 2012
                  • 597
                  #128
                  Almost. I'm considering to get either Condor mounts or notch the pan later on.
                  • UpstateMike
                    • Jul 2013
                    • 218
                    #129
                    Lookin good keep the pics comin!
                    • Garageaholic
                      Freestyle Fabricator
                      • Dec 2005
                      • 5204
                      #130
                      I love what you've done!! Any more sweet exhaust shots? What's your ecd for completion?
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      Instagram.com/garageaholic
                      Youtube.com/garageaholic
                      • MJCRO
                        • Apr 2012
                        • 597
                        #131
                        Should be another few weeks, just waiting on suspension and other goodies to arrive in the mail. Your exhaust lines up great! Just need to play with the v-band clamps until I have it flush with manifold. What about you?
                        • Garageaholic
                          • Dec 2005
                          • 5204
                          #132
                          Done!
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          • Jean
                            • 18228
                            #133
                            Frank - you crazy, i love it!
                            • MJCRO
                              • Apr 2012
                              • 597
                              #134
                              Damn Frank, you moved fast!
                              Ordered E39 525DTS mounts two nights ago like Garagistic recommended for their setup so I'll see how those work differently. These revshift ones have settled far too low and the pan started to touch the subframe.
                              Also, I have coilovers and an M-Tech 2 wheel coming next week. BTW anyone have a E30 blower fan speed switch for the HVAC? (part #61311381201). I need one on the cheap if anyone's got one, I can't find mine in the garage and I'm finishing putting the interior back together.
                              • MJCRO
                                • Apr 2012
                                • 597
                                #135
                                Happy to see this came in today. It's a 385mm fine spline I got from overseas.
