College kid M60 E30 (ongoing build)
  • MJCRO
    • Apr 2012
    • 597
    #46
    Originally posted by King Mufasa
    Have you installed the dash board yet?
    Not yet. Still need to pull out my harness and get to work on wiring. That reminds me, I need to upload those pics of the rebuild on my cracked dashboard.
    • MJCRO
      • Apr 2012
      • 597
      #47
      Update: May 16th
      The stuff from Wilwood came in. Pedal assembly and 5/8" compact master cylinders for the brakes and 3/4" for the clutch. My 404 ECU and ZF 310Z should be here tomorrow with more stuff coming next week too.
      • MT325is
        • May 2012
        • 1103
        #48
        Very nice to see you still going hard at it! i like it, and keep it up!
        1989 BMW 325is (SOLD)
        1992 BMW 325IC (SOLD)
        1991 BMW 318IS (STOLEN!)
        2017 BMW M2 (WEEKEND WARRIOR)
        1989 BMW 325IC (PROJECT(
        2002 FORD ESCAPE (DAILY)
        • MaxBell
          • 1390
          #49
          Very cool. I'll be paying attention to this, as I'd be interested in doing this as I get bored of the M50.
          REMEMBER: Be safe and have fun is Rule Number 1.
          The Epic Unbuild of Clint Eastwood
          • MJCRO
            • Apr 2012
            • 597
            #50
            Update: May 19th
            My radiator and transmission arrived yesterday. I also took a trip down to Gfest. I have some pics of my dashboard rebuild in progress. Still waiting on my clutch kit and stuff from Garagistic.
            Two coats of primer applied and cracks filled. Still needs more work to get it to look flush.
            ZF 310Z
            OEM Z3 M radiator
            404 DME
            • MJCRO
              • Apr 2012
              • 597
              #51
              Update: May 22nd
              Took a 7 hour round trip to r3v member FrankM's house to pick up his old entire exhaust setup which I'll be adapting for my swap. Stoked! Also got a coolant reservoir and some polyurethane mounts as well from him.
              Now just waiting on my stuff from Garagistic to get my motor in the car!
              • F34R
                sLaughter
                • 12390
                #52
                That exhaust system sounds really great.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • Jean
                  • 18228
                  #53
                  DAmn, moving quick!
                  • Wh33lhop
                    • 11705
                    #54
                    I like everything here except the part where you settled for a B30.
                    paint sucks
                    • MJCRO
                      • Apr 2012
                      • 597
                      #55
                      Update: May 22nd
                      Got the exhaust welded back together today. My stuff from Garagistic should be here this week as well.
                      • MJCRO
                        • Apr 2012
                        • 597
                        #56
                        Also for anyone who doesn't think the B30 is more than a capable platform, here's a thread a found on swapping the throttle body and intake manifold from the B40. I payed $450 for this motor so if I'm able to make that sort of power, then I made out quite well.
                        I have just tested a BMW E34 1995 with a M60B30 3-litre V8 engine where the intake manifold was swapped with a M60B40 4-litre manifold which has runners with larger diameter. The throttle body was also swapped - the B40 TB item is bigger (55 mm to 80 mm possibly ?). MAF is standard 3-litre item...
                        Also a dyno sheet from a member who shows the power gains on his motor.
                        I'm planning on doing this eventually for sure.
                        • MJCRO
                          • Apr 2012
                          • 597
                          #57
                          Update: May 23rd
                          My T55 long torx arrived. A T60 which is standard on all B40 flywheels did not work for me because some earlier B30's required use of T55 to get off the flywheel. Just a heads up to anyone considering this swap.
                          Also my Sachs clutch set arrived today.
                          • chance
                            • Feb 2012
                            • 671
                            #58
                            Cant wait to see it come together
                            1991 335is in progress
                            • garagistic
                              • Apr 2011
                              • 1712
                              #59
                              M60 mounts and brake booster on the way! We sent tracking numbers via paypal.
                              Shameless plug: M60 mounts + boosterless brake setup here! ;)
                              • MJCRO
                                • Apr 2012
                                • 597
                                #60
                                Thanks again! The stuff will be here next Tuesday.
                                Need a new flywheel.
