M60b44 #
  • driftingminor913
    • Sep 2011
    • 358
    #151
    Originally posted by Vtec?lol
    I've got the gargistic mounts
    I'm impressed.
    I do too, I just have the motor in the furthest holes toward the front of the car. And thank you hahaha you did say hogwarts graduates right? Lol
    Because V8
    http://www.r3vlimited.com/board/showthread.php?t=282219
    Doing it wrong since 91:wgaf:
    • Vtec?lol
      • Dec 2009
      • 3278
      #152
      Yes. Your wand has a nice touch
      • driftingminor913
        • Sep 2011
        • 358
        #153
        Lol bought these to finish up the exhaust for now, will work brakes for now then drop everything in.
        Because V8
        • driftingminor913
          • Sep 2011
          • 358
          #154
          Down pipes are done for now.
          Because V8
          • Vtec?lol
            • Dec 2009
            • 3278
            #155
            Get some light in these pics I can't see!
            is that tig or mig work?
            • driftingminor913
              • Sep 2011
              • 358
              #156
              It's all TIG work
              Because V8
              • JCarp90
                • Feb 2011
                • 1759
                #157
                What do those pipes do?
                • Zacm829
                  • Jan 2008
                  • 1919
                  #158
                  Nice work!
                  1987 325i-M60b44 swap
                  • driftingminor913
                    • Sep 2011
                    • 358
                    #159
                    So I'm stuck
                    On my wiring I got a harness from one of the members here and the first problem, is that the knock sensors I'm using are 2-pin and the connectors on the harness are 3-pin. Second issue is that I kept some
                    M62 parts like the Alternator, starter, and oil filter housing.. I noticed the M62 alternator just has a plug on the back of it. And the M62 starter is just 1 big plug. And there are no big plugs on the M60 harness for the starter or alternator.... So dpi need to swap
                    Out the alternator and starter for a m60 one? Or what? And get a match harness for the knock sensors??
                    motors close to being started so just need this info
                    Because V8
                    • driftingminor913
                      • Sep 2011
                      • 358
                      #160
                      Bumpzz
                      Because V8
                      • driftingminor913
                        • Sep 2011
                        • 358
                        #161
                        Can anyone sheds some light?
                        Because V8
                        • alco
                          • Feb 2013
                          • 197
                          #162
                          You will want to use the knock sensors that match your harness, plain and simple. For the other things, I haven't looked into that on my swap yet so I have no advice at this time except that perhaps they can be pinned out and appropriate pigtails sourced.
                          Velocity Motor Works
                          1972 2002
                          1983 533is
                          1987 325is (Roxanne)
                          1988 M6
                          1989 M3
                          1989 325ix (Darth Maul)
                          Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
                          • Zacm829
                            • Jan 2008
                            • 1919
                            #163
                            Why would'nt you just source a complete m62 harness to use?
                            • driftingminor913
                              • Sep 2011
                              • 358
                              #164
                              Because M62 is OBD2, and I'm going OBD1
                              Because V8
                              • driftingminor913
                                • Sep 2011
                                • 358
                                #165
                                I will look further into detail on the harness and see what I can make of it. I just glanced over it.
                                Because V8
