M60b44 #
    Originally posted by driftingminor913 View Post
    It's a Nissan 240sx (s13) coupe, that has a motor out of a infinit Q45. Which is equivalent to our M60 swaps but instead it's a 4.5 quad cammed v8 in the Nissan world that makes 300+ hp
    Thanks for the translation ... I barely know BMW codes I'm getting better in M60 speak:)
    My CA legal M60 swap
    The happening in our garage
      That and just a hard-on for V8's in stuff there not supposed to be in
      I sympathize.
      I learned to drive in a '75 Datsun with 4.3 V8 from a '95 Caprice with Saginaw 4 speed + Borg Warner overdrive that my dad built.
      I have an '87 Pontiac Fiero with a built Caddy Northstar engine... 4.6 liters and 312 HP at the wheels right now... setting up for cam upgrades, ported heads, upgraded manifold and more.
      I'm also building an E30 S62 AWD, but still collecting parts.
        ALIVE bitches!
        Well it runs!!:D will upload vidz when I can. But it's a good feeling now that half the battle is now down.
        Because V8
        http://www.r3vlimited.com/board/showthread.php?t=282219
        Doing it wrong since 91:wgaf:
          Congrats!
            Awesome, congrats!! Now let's see some videos....
              I'm working on it lol
              Because V8
                This thread fucking sucks. Where are the videos?
                  What did all of you guys with 530i manual or
                  Auto harness do
                  For the alternator? Cause I still have my M62 alternator on it but I don't have the 3-pin plug on my harness, just a ring terminal wire that is BLUE/BRWN
                  I looked up new alternators and none of them have a plug on the back just one for power and a couple of other studs on the back...? I'm kinda drawing a blank, alternator has power but where do I get the signal for letting the DME know it's charging and what regulates the voltage if there is no plugs?? Confusssssedd
                  Because V8
                    Auto harness do
                    ha, Dealing with the same thing but I looked at the older alts and they didn't have the plug, and I'm guessing that ours with the two bolt prongs and plug will work the same with out using the plug.
                    The larger prong is the constant +pos from battier via the starter constant, and I'm guessing that the small prong is the feed to the dme.
                    we have no Plug on our harness so I wouldn't sweat it.. My take on it is if the Alt doesn't charge then I'll swap it out for an older 94-95 alt...
                      Okay cool, and I think the further I looked into it that there are different designs, where the OBD2 Alts have those 3 pin plugs and the power stud. Where as the older ones just have the power stud an a smaller stud for the signal to
                      The DME an I guess the regulator is just built inside.
                      Because V8
                        I was under the impression that none of the accessories from the m62 fit other than the starter?
                          Got the correct alternator, everything fitted perfectly, now on the hunt for a throttle cable cause apparently world pack doesn't supply them? But others the that and it snowing it's ass of in KS just need to put the radiator I and bleed coolant and go for a drive :-)
                          Because V8
                              First start :-) sorry for delay
                              Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                              Was super happy at that point but right now in just redoing something's that I was being stubborn about, but once the steering is back in it there will be burnout videos
                              Because V8
                                Kudos & Congrats to you !! ^^^
