E30 V8 Swap Stainless Exhaust Headers M60 M62 S62
  • Turk
    • 223
    Hi all.
    We have just released our E30 Ready V8 manifold kits and we'd like to offer all you lovely r3v'ers some money off!!! Fitment designed to fit M60, M62, S62 engines etc
    Just a quick rundown of the product -
    Made from 304 stainless steel 45mm tube
    Laser cut flanges
    minimal welding
    Available for right & left hand drive cars.
    Designed to work with E34 steering knuckle kits
    Designed using the 300mm.de engine arms
    Works with 10-20mm subframe spacers
    Supplied with a roll of exhaust heat wrap (up to you whether you use it)
    Available in both RHD & LHD
    Our forum and Facebook member price is £950 plus postage.
    We can also Supply a bolt on exhaust system to match. These will be made to spec so please get in touch with your requirements.
    Thanks for looking!
    info@ergen.co.uk
    Plug and Play S54 & S62 loom/Ecu Kits - Fit you engine to ANY car!!!
    M50 Sump Baffles
    High Torque Clutch Kits
    Custom Flywheels
    E30 Engine Conversion Kits
    http://www.bmw.ergen.co.uk
    LIKE our Facebook page for regular car porn :)
    http://www.facebook.com/ergenltd
  • dirty30
    • 3014
    I must have these.
    • LJ851
      • 7919
      Originally posted by Turk
      Mandrel bent
      Those aren't mandrel bent, son.
      Lorin
      The M30 is God's engine.
      • E30SPDFRK
        • 5708
        Came to say this.
        Awesome product though, about time someone made a set of bolt on headers for this swap. Do you have any installed pictures to show the fitment?
        Byron
        Leichtbau
        • Jean
          • 18228
          Oh man! I guess I am "Glad" that I live in CA where these would not pass inspection LOL
          • alco
            • Feb 2013
            • 197
            Why wouldn't they pass inspection? Because they're not OEM?
            Velocity Motor Works
            1972 2002
            1983 533is
            1987 325is (Roxanne)
            1988 M6
            1989 M3
            1989 325ix (Darth Maul)
            Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
            • alco
              • Feb 2013
              • 197
              Also, they're definitely not mandrel bent. Take a look: http://www.youtube.com/watch?v=G9z2pAmk3XI
              1972 2002
              1983 533is
              1988 M6
              1989 M3
              • driftingminor913
                • Sep 2011
                • 358
                Fuuuuuuck soooo expensive
                Because V8
                http://www.r3vlimited.com/board/showthread.php?t=282219
                Doing it wrong since 91:wgaf:
                • slammin.e28
                  שמע ישראל
                  • 12054
                  Welcome to the world of BMW v8s. Enjoy your stay!
                  • Jean
                    • 18228
                    Because California.
                    • driftingminor913
                      • Sep 2011
                      • 358
                      Yeah I'm quickly learning about that as in rounding up my swap, I have about 2400 into and my motor is still down to just the bottom end....not even no where near assembled
                      Because V8
                      • Turk
                        • 223
                        Description edited. Not mandrel bent my apologies.
                        Thanks for the comments guys, both positive and negative :) We always aim to improve our products moving forward and (constructive) input is always welcome :D
                        We feel for a bolt on solution to the V8 swap the pricing is quite reasonable. Especially considering 2nd hand, double wall'd restrictive oem manifold that you have to butcher to fit can be £250 on ebay (at least in the UK)
                        We also have e30 ready S54 Header kits too :)
                        Thanks for the responses guys!
                        M50 Sump Baffles
                        Custom Flywheels
                        • Turk
                          • 223
                          We can also offer them pre polished for those who arent going to wrap them.
                          Here is our S54 e30 Header kit:
                          M50 Sump Baffles
                          Custom Flywheels
                          • E30Strube
                            • Jul 2008
                            • 181
                            The S54 headers look like the standard setup for an E46 (or even ebay headers). What is different about yours?
                            • Wanganstyle
                              • 2828
                              The S54 headers pictured above are the ones sold on amazon and ebay; one of the names associated is "sure win racing" - around $110.
                              they are also sold by VAC motorsports as a "direct install set" for $700. Pick your vendor!
                              A local friend just ordered some off amazon prime this jan (2013). We will see if the tolerances around fit is same as 2009; they are 100% made in china and not bad quality- never had an issue in 5 months of daily drive use.
                              Those headers actually fit great but the hardware and included gaskets are garbage.
                              I installed those in 2009, think it cost me less than $170 total to order all new parts needed:
                              (headers ~ $106 shipped, $65 for gaskets, nuts, new 42mm studs
                              notes from my 2009 s54 swap:
                              order these new parts:
                              18x 42mm studs from m50b25 needed; order 18 as the s54 is 3 per cylinder instead of 4 like a M50.
                              18x 11mm copper exhaust nuts
                              6x s54 exhaust triangle gasket
                              Don't even think about installing the china crap gasket/hardware joke on a S54; remove the plastic pack from the header box and drop it directly into the trash (do not even open plastic pack as it will contaminate your garage with garbage)
