You must read through the entire swap write up carefully. I'm using the lightweight flywheel kit from uuc. It's is originally equipped for the s62, but I used it for my m60 swap at the time. With that being said, the flywheel had the teeth necessary for crank position. Now that I am doing s62, the flywheel is compatible and works in this application. As you can see, I modified the transmission to accompany the crank sensor.
Now according to your logic and having proven you on your one comment, my swap is perfect!!
