Ok I put loc tight on the oil pump bolts, replaced the upper oil pan gasket, cleaned out the intake ports and manifold got my alternator and dme.
I have the x20 connector but can't find a c101..anyone know somewhere that sells them
Ok so I ran into a few problems..
1. The e30 DSSR is way too short
2. My e34 engine mounts don't work..the stud is way offset and there are two studs coming out the bottom (wtf?) so a buddy gave me his old e36 m3 mounts which seem to line up ok but the oil pan sits on the subframe.. Other than that, things are going pretty good
Eh by the time the wiring harness and plastic covers are on you'll barely even be able to see the color.
Is it a good idea to get my selector rod lengthened? Will it be strong enough?
So I'm just really confused about the whole mounting situation. First off, pelican only sent me one mount (right side) so I tried to use the old one off the m60 but that was a right side as well. They have offset studs on the top (engine side) which seem to mess everything up
So basically I have two right side e34 mounts and two m3 mounts which have a centered stud so side doesn't matter. These lined up but the pan was sitting on the subframe. Even with an e34 mount on the correct side it still seems to be way off
My engine has been dangling since Friday and I can't get selector rod measurements until it's bolted down
Don't you have to put spacers under the (rubber/whatever) mounts for these swaps? And then put spacers between the body and the subframe? Not too sure, not that familiar with this swap. Take a look at this thread:
So I ghetto rigged the shit out of some old e36 mounts so I could just get the cherry picker out of the way.
Yes. That is plywood.
The pan sits 1-2mm above the steering rack but at least I can go ahead and finish putting everything back on the engine.
I have a traction control throttle body..I guess I'll just live with it for now. A few of the injectors are broken and some have rust. I've never really wired anything before and my harness if from an autotragic so there's so much unnecessary shit on it. I'm hoping that my e32 2 piece exhaust manifolds will fit. I don't think I have time to get x5 headers and make a full exhaust system so I'm just going to run open headers for the meantime. Also the engine sits wayy off center. I'm hoping that when I get the proper mounts this will be corrected. Also I still need to source an e36 driveshaft.
Yup, I too had the e30.de kit with 540 mounts, and had the same problems you do. Engine wasn't sitting straight and all that. I ended up doing new engine mounts......
