My M60 swap
Ok I got the engine mounted properly using the correct m60 mounts and a few washers
Got the heater lines and reservoir hooked up
Got the shifter linkage fixed
Almost done with the cooling.. Just trying to find a solution to the oil filter/upper rad hose problem
Sent from my iPhone using Tapatalksigpic'89 325i
M60 swap in progressComment
I´m having a plate CNC´d to fit the block with AN10 fittings for the oil filter/cooler. It'll be a bolt on solution, much cleaner than the OEM/modified OEM stuff. I should have it in a week or so, I'll post some pics when I have it :D BTW, the gold foil looks good! ;)Comment
Interested in the pictures of this!
Good job Jack!Comment
Solved the oil filter housing mounting
Got most of the wiring done..
Shifter is in and feels awesome!
There will be some burnout vids, don't worry. Maybe even 3rd gear burnouts considering I'm running a 3.73 open diff and cheap tires. This is all assuming my ebay m52 clutch holds up..
you might not want to do burnouts right away because it usually good to let the clutch/drivetrain to settle in for at least a couple hundred milessigpic
86 E(In the car is in a million pieces stage of making it into a bar'd 340E)
89 I(bar'd swapped)Comment
Yea that clutch manufacturer recommends a 500 mile break in period..this is going to be very difficult
I have a SPEC Stage 3 in my Northstar Fiero. I decided I'd rather break in the new engine and worry about the clutch later, so I beat it hard from the first start. The first time I hit a 1-2 shift hard I smelled slipping clutch and it's chattered ever since, despite now holding very well.
Convincing? ;)Comment
Yeah, it's not fun. It basically requires an overhead hoist. A cherry picker won't cut the mustard.
Yeah, I don't think OP's engine was overhauled... just saying that it's a good idea to observe the clutch break-in. ;)Comment
