M62B44 1991 318is Swap
  • Denny
    • Jan 2010
    • 822
    #76
    cool man :) lets do this... for me soon as I get my M5 clutch it opens the door for a lot of stuff for me too. ...but with Xmas holidays..etc.. i see January-February as a BIG month of work.
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • CMart
      • Mar 2014
      • 156
      #77
      Nothing too crazy on the E30 progress wise.
      I did get the 540 out of my garage, which is really helping with space. Picking up a bunch of tools I will need to get everything fabricated (band saw, welder, grinder, vice) and a new snap on toolbox I am excited about.
      Radiator support is almost out.
      Basically just getting ready to get everything ready to weld then on to wiring/plumbing.
      • CMart
        • Mar 2014
        • 156
        #78
        • CMart
          • Mar 2014
          • 156
          #79
          So I got my engine and trans back together and they made their way into the E30 for the first time.
          I know that the 6 speed is longer than the 5 and you need to shorter the driveshaft, but the shifter won't fit in the hole in the E30 chassis. This makes sense, but I hadn't read that anywhere.
          Do I need to buy a new shift fork setup or am I doing something wrong?
          • CMart
            • Mar 2014
            • 156
            #80
            Definitely looks like I have to shorten the two shifter pieces. Has anyone measured this before to save me from eyeing it?
            • CMart
              • Mar 2014
              • 156
              #81
              Also do you need to do any tunnel 'massaging' for the 6 speed?
              • Denny
                • Jan 2010
                • 822
                #82
                Tight fit for 6 speed but all ok for me.... my problems is that I had to shim the front engine mounts.. especially the passenger side. It was touching the steering rack...i should of modified the tabs on the front subframe before installing engine..
                Also the alternator was touching the frame..had to grind down some material on the alternator.. all good now.. thats a big ass engine lollll
                Denny
                ___________
                Blogs:
                • CMart
                  • Mar 2014
                  • 156
                  #83
                  My motor is sitting fine both height and depth, but the trans is touching the tunnel. Not the bellhousing behind it. I am not able to attach the trans mount because the trans is hitting the tunnel.
                  • CMart
                    • Mar 2014
                    • 156
                    #84
                    I don't know if these pictures help, but the top of the trans is hitting the tunnel and the trans mount (not welded yet) would just press it up harder if I bolted it up. Only thing I can think at this point is I need to wide the tunnel or I have the wrong rubber trans mounts.
                    • straight6pwr
                      • Sep 2004
                      • 3450
                      #85
                      i thought the 6 speed needed a custom trans mount.
                      scroll down in this link to find it: (6 speed transmission extention brackets)
                      Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
                      and post #75 here:
                      • P Arkus
                        • Dec 2012
                        • 325
                        #86
                        ^^^This is correct. I believe you also need to massage the transmission tunnel a bit to allow the 6 speed to fit.
                        Originally posted by 36brua
                        Isn't that what these forums are all about making stuff easier... OO no never mind this is r3v...
                        Patryk:up:
                        Instagram: @parkus08
                        91 BMW 325is ///M-Tech II
                        08 VW .:R32
                        04 Audi A4 Avant 1.8TQ
                        • Denny
                          • Jan 2010
                          • 822
                          #87
                          and post #75 here:
                          http://www.r3vlimited.com/board/show...=310389&page=2
                          Yep you are correct. Cmart look in my thread I have built extension from Garagistic. If the tranny is touching the tunnel then I think your motor is not sitting straight... because trust me my 6 speed does not touch anywhere its close.. but not touching and sits parallel. I did have to shim the motor mounts so the oil pan doesnt touch the steering rack...but thats it.
                          no massage needed for the 6 speed... modifications to the tunnel are for the Automatic transmission.
                          Denny
                          ___________
                          Blogs:
                          • Denny
                            • Jan 2010
                            • 822
                            #88
                            Originally posted by CMart
                            In this picture your motor mounts bolts should both be pointing towards the firewall... that is your problem right there
                            Denny
                            ___________
                            Blogs:
                            • CMart
                              • Mar 2014
                              • 156
                              #89
                              540i mounts don't work for me.
                              I do have some good news to report, after some gentle 'massaging' of the tunnel and fun with the welder, the motor is finally sitting where it will live. Angle seems fine for the drivetrain as well.
                              Now I can measure the new driveshaft and start working on brake options. I do have 2 full e34 540i headlight mounted brake booster setups, but I think there is a better way then cutting into the frame. Updates to come.
                              • CMart
                                • Mar 2014
                                • 156
                                #90
                                It's been a while since I have updated this.
                                Motor and trans are in and sitting where they will be for good. Got a custom made driveshaft, shifter modified, radiator support is now removable with a few bolts, remote brake booster mounted and all the linkage is ran.
                                Really all that is left is finishing up the exhaust, plumbing the fluids, and wiring.
                                I have been doing a lot of research on the wiring and frankly a little overwhelmed. I think I just need to get everything plumbed, start wiring what I know and go step by step from there.
                                Are there any writeups on the M62B44 keeping OBDII? I know I use the C101 and then need to give power to the fuel/starter/main/etc, but I don't want to screw something up and fry my ECU. Also, I need to hope I kept did a good job chasing wires from the EWS so that doesn't create a problem.
