And... Just looked back through your thread, yes, you had replaced the gaskets and pulled both pans. Damn
Denny's M62B44 swap (MS2 installed First start VIDEO inside)
Yea pre vanos b44 are 97-98 maybe 99 but not sure. They also came in the range rover, and never got vanos
Sent from my SM-N910P using Tapatalkhttps://www.forabodiesonly.com/mopar...re-irs.356333/
Originally posted by smalcol View PostHey Denny, sorry to see this, damn.
A quick search didn't show anything to disable Vanos. There are a few other things that changed along with Vanos being added. DBW throttle, water cooled alternator. I would look for a pre-vanos motor or M60.
Is this the first time you've had the lower pan off the motor? Did your oil pressure light not come on?
Originally posted by smalcol View PostAnd... Just looked back through your thread, yes, you had replaced the gaskets and pulled both pans. DamnOriginally posted by MonkeyMadness View PostYea pre vanos b44 are 97-98 maybe 99 but not sure. They also came in the range rover, and never got vanos
Sent from my SM-N910P using TapatalkDenny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/
m6x's are a dime a dozen, just grab another. There's 3 pick n' pulls within 1 hour of me, all of them have at least 2-3 m6x's every time I go. They charge $125 for any engine. 99% of m6x's don't fail mechanically like yours did, if the guides are done. Replace the guides, feed them oil, and they run forever. I'm running a random junk 200k+ mile m62 block with warped 160k+ mile m60 heads. I regasketed it, put guides on it, and compression is dead even across all 8. I have 25k miles on it in my e30, and literally beat the shit out of it every day on my 100 mile commute. Full throttle, 7k rpm's, no mercy. And that's with the nearly 11:1 compression of the m60b44 combo, running an m60 tune. There's also a lot of turbo m6x guys running 10+ psi, 600+whp on stock, unopened engines. They're strong.
IMO, it's not worth building the engine. You'll have $10k+ into a build and barely make s62 power. Sleeving I can see, if you want to go to big boost.
Bentley used a boosted twin screw stock version of the m60 and had no issue. There built for boost and detuned for road use.
Originally posted by MonkeyMadness View PostBentley used a boosted twin screw stock version of the m60 and had no issue. There built for boost and detuned for road use.
Sent from my SM-N910P using TapatalkOriginally posted by JGood View Postm6x's are a dime a dozen, just grab another. There's 3 pick n' pulls within 1 hour of me, all of them have at least 2-3 m6x's every time I go. They charge $125 for any engine. 99% of m6x's don't fail mechanically like yours did, if the guides are done. Replace the guides, feed them oil, and they run forever. I'm running a random junk 200k+ mile m62 block with warped 160k+ mile m60 heads. I regasketed it, put guides on it, and compression is dead even across all 8. I have 25k miles on it in my e30, and literally beat the shit out of it every day on my 100 mile commute. Full throttle, 7k rpm's, no mercy. And that's with the nearly 11:1 compression of the m60b44 combo, running an m60 tune. There's also a lot of turbo m6x guys running 10+ psi, 600+whp on stock, unopened enging.
IMO, it's not worth building the engine. You'll have $10k+ into a build and barely make s62 power. Sleeving I can see, if you want to go to big boost.Denny
___________
Blogs:
Anybody know if i can use a m62b44tu block with m62b44 non vanos heads?? Reason is because 90% of available donor cars in my area are vanos...Denny
___________
Blogs:
Yes the short block will swap.
Front covers and heads will need to be swapped.
___________
Blogs:
Well i found the problem....
Rod bearing piston 2 and 6 destroyed and fused together was a bitch to remove...crank is garbage but lucky mains are ok.... So i'm getting another engine tomorrow.... Now how this happened i got no f*cking clue...Denny
___________
Blogs:
Originally posted by Denny View PostWell i found the problem....
Sent from my SAMSUNG-SGH-I337 using TapatalkSi vis pacem, para bellum.
New Hawtness: 1995 540i/6 Claptrap
Defunct too: Cirrusblau m30 Project
Defunct (sold): Alta Vista
79 Bronco SHTF Build
Originally posted by Tjabo View PostVANOS and drive by wire throttle are two of the problems with it in my book. I guess maybe if you're swapping in a factory DME with the appropriate EWS and ring antenna it could be ok... What a pain that would be though. Haha
