LS3 480 in a E30 m3 convertable conversion.
    He's talking about the Countache V12.
      If I ever build a coupe I would go v12😊
        Lol i totally missed that in the background.
          Are you planning on shortening the driveshaft for that extended tail housing?
          Alpine White 1989 E30 Coupe - LS1/T56
            The drive shaft comes in the sikky kit.
              Yes, but the trans in the picture has an extended tail shaft section in comparison with an F-body / GTO T56, which is what the kit and sikky driveshaft is based on
                Is it? Looks the same as mine.
                  I ordered an f body transmission. The Shifter lines up perfect. I'll try the shaft next week.
                    Magnum trans. Notice the tail section protruding beyond the shifter.
                    Stock F-body T56.
                    I mistakenly assumed OP was going for the Magnum trans.
                    :thumbs up:
                      I guess there is an easy fix for that.
                        oooooooooooooooh I never knew. cool trivia fact.
                          The tail sections can be swapped out. But it's costly and requires swapping internal items from what I'm told.
                            I'll send it back. They sent me the wrong one.
                              Just got off the phone with Tremec. The magnum comes with the extended tail housing. I must cut my drive shaft. Shifter position works, so that's all that counts for me.
                                Engine bay is ready.
                                Trunk is ready.
